E 350 van tires
Old Nov 29, 2003 | 03:26 PM
Submariner's Avatar
Submariner
E 350 van tires
I have a 03 E 350 cargo van with a v 10 engine that I take off road. What size tire and what kind do you think will be more agressive than the stock ones since it is only 2 wheel drive ?
Old Nov 29, 2003 | 08:49 PM
pfogle's Avatar
pfogle
Any good LT tire that has the same size as the stock.
Old Nov 30, 2003 | 07:15 AM
Submariner's Avatar
Submariner
One other question. What kind of mods can I put on the van to increase the mileage and if possible the power. From all my searches on the internet nobody seems to make any aftermarket parts.
Old Nov 30, 2003 | 08:41 PM
pfogle's Avatar
pfogle
The tuners for the trucks will work as the drivetrain is the same.
Old Dec 1, 2003 | 09:48 AM
Submariner's Avatar
Submariner
vans
ya can't get a k7n filter for a v 10 van or pipes. ford says no larger tires than their 245's...any ideas that have been tried out ??
2003 e 350 v 10 3;73 rear
Old Dec 1, 2003 | 03:35 PM
pfogle's Avatar
pfogle
Okay, here's what you need to do. Call Superchips and order a tuner. Then you can put up to 315s on it. The K&N filter should be the same as the one for the truck, have them check the paper filter numbers if they are the same then get the truck filter. Pipes will have to be custom fabricated by an exhaust shop, as the wheelbases are different for the van and the truck.
Old Dec 3, 2003 | 02:00 AM
Kaleo's Avatar
Kaleo
Tires look into BFG all terrains or mud terrains, also super swamper Trxus M/T. Relativlly good prices on all three, about $140 a tire. Not sure if 315/70/16 would work because of the width, 12.5" 385/75/16 may be a better choice, litte narrower and will fit on stock wheels, so they shouldn't rub on the fender when turning and flexing. That's my suggestion "IF" 33" tires will fit, I personally don't know for sure.
I have a 4x4 that sitts about 4" higher than a 2wd. I had to trim bumper and rear edge of front fender to keep tires from rubbing when turning and flexing suspension. Rears fit fine with no mods. I run 35x12.5/16.5 on 8" wide wheels.
Old Dec 3, 2003 | 02:03 AM
Kaleo's Avatar
Kaleo
Locker or L/S in the rear, good idea if you don't already have one.
Old Dec 5, 2003 | 07:37 PM
Qvan666's Avatar
Qvan666
Take a look at the Pirelli scorpion line of tires. My next set for my 4x4 van is going to be the pirellis.
http://www.tirerack.com/tires/tires....Scorpion+A%2FT
bob
Old Dec 16, 2003 | 01:51 PM
shorebird's Avatar
shorebird
Banks makes an exaust system from the headers on back. But be prepared to dig deep into your wallet. It is the system for the class "C" RVs. Aftermarket air filter companies (Green,Blue,Red colored) all make direct replacement units. A Superchips 1715 Max Micro Tuner also is recomended.
Old Dec 17, 2003 | 10:09 PM
cocot's Avatar
cocot
I just got an Accel Kool Blue filter for my van. The air box for the 4.6, 5.4 or V10 is the same.
I had 265's on my last van and they would just slightly rub.
May 21, 2012 08:46 AM
ptt
18
May 14, 2006 06:42 PM
motododo
Modular V10 (6.8l)
Mar 29, 2006 03:46 PM
cubman61
Jan 20, 2004 06:44 PM
