Steering gear box question
Old Sep 15, 2024 | 11:41 AM
Doppler 1963's Avatar
Doppler 1963
The right front tire on my 2002 dually is wearing on the outside. I took it down to get an alignment and they quoted me 3,500 for parts and labor. They said I need all ball joints every arm and the steering gear box. They said the steering gear box has up and down play on the out put shaft. When I got it home I took a pry bar and pried up on the pitman arm where it connects to the shaft and it has close to 1/4 inch play when prying up on it. They said there should not be any play. I can’t find anything that says how it should be either way. It’s not leaking and seems to steer good. Y’all’s thoughts on this?
Old Sep 15, 2024 | 12:04 PM
Dan V's Avatar
Dan V
Get you some Spicer or XRF ball joints and the brands for the tie rod ends and drag link. Get a Blue Top or Red Top gear...solved.
Old Sep 15, 2024 | 11:05 PM
Eman85's Avatar
Eman85
Are you saying that the pitman shaft inside the box moves up 1/4" when you pry up on it? This is the shaft that the pitman arm mates to with the big nut on the bottom. If so that ain't good.
Old Sep 16, 2024 | 12:14 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
If there are no other issues with the truck buy a used tire and keep on trucking.
But I'll guess the steering is sloppy and it wanders all over the road. Ball joints wear kinda fast on these.
Old Sep 16, 2024 | 03:08 AM
udsuth78's Avatar
udsuth78
The shop is correct. There shouldn't be any noticeable play in the shaft. The steering gears on these trucks were and are crap. If you check you'll find that Ford changed the gears every few years on the Super Duty's. Why? Because they were crap. Way undersized for task in stock flavor, add bigger rubber and screw the already lousy steering arm geometry up even more with a lift and it's a wonder they're not puking their guts out it driveways across the country.
Old Sep 16, 2024 | 07:37 AM
Doppler 1963
Alright I was hoping some end play would be allowed. The truck pulls to the right but other than that steering feels good. The truck has 153k. I do feel play in the ball joints when lifting the tires. Looks like I’ll be having fun changing everything. Thanks for your input.
Old Sep 16, 2024 | 08:31 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Spicer suspension parts and BlueTop steering gear have my vote. I went through two POS gears from parts stores before going BlueTop and have zero regrets.
Link to more information: https://www.ford-trucks.com/forums/1...l#post19805263
Old Sep 16, 2024 | 09:51 AM
Doppler 1963
Who sells spicer ball joints? Not AZ or oriellys. I see kits online from eBay and Amazon but I don’t trust them.
Old Sep 16, 2024 | 11:31 AM
Sous's Avatar
Sous
FTE Emeritus
Rock Auto, Ventures Truck Parts (Ogden UT) and I think Torque King.
Old Sep 16, 2024 | 11:53 AM
knottyrope's Avatar
knottyrope
Spicers failed in 3 months
I went XRF after and yes they are on ebay with million mile warranty
Old Sep 16, 2024 | 12:48 PM
Dan V's Avatar
Dan V
And the local Ford dealer.
Old Sep 16, 2024 | 03:29 PM
dsrace's Avatar
dsrace
I went with a blue top and like it. Check your steering shaft as well. At under 140k miles mine was so bad I had to replace it.
Old Sep 16, 2024 | 06:42 PM
John in OkieLand's Avatar
John in OkieLand
reading all of this talk, makes me wonder if my truck has had the steering box replaced?
I had to put a new Pitman arm on it one week after I bought it, but the box itself is doing a good job at 180k miles.
Plus a lot of new parts, the Drag link was slipping almost two inches which let the left/right wheels wander a lot.
it used to be a Fire Truck, so it should have had a lot of U-turns in its' life.
traxx808
Mar 27, 2013 07:54 AM
partlyian
1966 - 1977 Early Broncos
Aug 19, 2010 07:57 PM
98SurplusExpy
Oct 29, 2009 09:39 PM
3Nails
1978 - 1996 Big Bronco
Jul 16, 2008 06:12 PM
sancochojoe
Jul 21, 2006 02:13 PM
