How to release EEC Test connector ?
Old Sep 2, 2024 | 01:58 PM
Tchenkov's Avatar
Tchenkov
Trailering
Hi everyone,
I’d like to check for error codes on my ‘90 Econoline and it seems very easy to do but I’m afraid to brake this connector holder, how do you release the connector down there ? I tried to lever the red thing and pull it down but it won’t come
should I insist or is there a trick ?
Old Sep 3, 2024 | 07:05 AM
manicmechanic007's Avatar
manicmechanic007
2024-1990 is 34 years
The plastic gets brittle
Insert screwdriver into the red slot and hope for the best
Most likely the connector will be okay, but you will break the relay holder that also holds the VIP connector
Not the end of the world either way, just make sure the relays are under the cover mounted vertically
The self test connector can get wet, the relays not so much
Most of those VIP connectors are just laying there under the hood
Yours must have not had too much EEC trouble over the years
Old Sep 4, 2024 | 04:46 AM
JWA's Avatar
JWA
When I encounter a connector that seems old enough it would break with very little prying ect I grab a hair blow dryer and gently warm it up before and during the attempt to disconnect it. Heat guns can be too hot unless they have a temperature controller. Sadly time makes those parts brittle, heat can be helpful sometimes.
Old Sep 4, 2024 | 07:09 AM
Tchenkov's Avatar
Tchenkov
Trailering
Hi,
thank you both for your help on this, I really appreciate
reassured by your advice I had a closer look and I noticed a second clip on the other side of the holder
it was not easy to access (the holder is attached to the relay cover), I had to use a blade-shaped tool to maintain the hidden clip and the first one with my thumb while I pushed the connector down , and it finally unlocked with no damage !
after that the grey single-cable connector was just inserted but with no clip
success !!
next step I'll go for a warm up when the weather will be better and do a KeyOnEngineOff test (luckily the INNOVA ODB code reader came with the van)
(sorry for my english if there are mistakes)
matkinson13
24
May 9, 2024 09:46 PM
McMaster
Jul 20, 2010 06:00 PM
ENCSDEI
Apr 8, 2007 09:00 PM
xraylee
May 6, 2006 09:09 PM
wildfowler1
1978 - 1996 Big Bronco
Sep 10, 2002 11:39 AM
