Odd OBD1 test connector
Old Jul 18, 2010 | 05:16 PM
McMaster's Avatar
McMaster
My 1993 F 250 has an odd OBD1 test connector. Instead of the usual 6 pin (4 on the bottom, 2 on top), mine is a 4 pin - all in a row. I need to get the codes but can't find a code reader that fits, and all the instructions on getting the codes without a reader use the 6 pin connector. If anyone can tell me how to do the test with this connector, I would appreciate it.
Old Jul 18, 2010 | 05:30 PM
White 97 xlt's Avatar
White 97 xlt
Not trying to be a smart a$$, but, you need to look near the left (drivers side) hood hinge for the OBDI connector.. The 6 in a row plug ain't it...
Old Jul 18, 2010 | 05:45 PM
McMaster's Avatar
McMaster
That's where it's at, but it's not a 6 in a row, it's a 4 in a row and it has the STI connector mounted next to it. It looks like the 6 pin, but without the two upper pins.
Old Jul 18, 2010 | 07:15 PM
f-150_1993's Avatar
f-150_1993
Do you mind taking a pic of it?
Old Jul 18, 2010 | 09:18 PM
McMaster's Avatar
McMaster
I'll take one in the morning and post when I get home. I was hoping it wasn't as odd-ball as it seems.
Old Jul 19, 2010 | 06:44 AM
subford's Avatar
subford
Also what are the wire colors that go to it and the color of the stripe on the wire if it has one?
Old Jul 19, 2010 | 09:11 AM
McMaster's Avatar
McMaster
When I turned it over to get the wire colors, I found that it is the standard 6 pin connector. Someone had done such a good job of taping it back together (and covering holes), that it looked original. Thanks.
Old Jul 19, 2010 | 09:34 AM
Lazy K's Avatar
Lazy K
Ford Fuel Injection How To Run a Self-Test Here is how to get the codes withiout a code reader. Yours should be 3 digit codes.
If your check engine light is working ignore the part with the meter and test light.
Old Jul 20, 2010 | 02:40 PM
McMaster's Avatar
McMaster
Thanks to all. I had always just had the parts store run the code check for me (free), but their tester wasn't working. But as easy as that was, I'll just do it myself from now on.
Old Jul 20, 2010 | 06:00 PM
ymeski56's Avatar
ymeski56
Der Postmeister
johnanderson
15
Feb 9, 2023 08:20 PM
TexanAmmo
May 7, 2017 08:15 PM
liljohn
16
Apr 25, 2011 09:32 AM
FlatlanderKW
Aug 4, 2010 04:18 PM
Britar
Nov 4, 2009 06:31 PM
