DPK Options
Old Oct 29, 2024 | 09:13 AM
  #46
augam's Avatar
augam
I agree cutting that molded part off and clamping a piece of fuel line to that pipe is a bit janky.
Old Oct 29, 2024 | 10:10 AM
  #47
acdii's Avatar
acdii
Bingo, that was my deciding factor over all else. I was going to pull the trigger on the S&S until I read the instructions. That last bit put a dead stop on it.
Old Oct 29, 2024 | 12:30 PM
  #48
Overkill2's Avatar
Overkill2
Originally Posted by acdii
True, but that doesn't address my other issues with the kit. I don't find it aesthetically pleasing for one, and two, I don't want to do any modifications to the engine, I want fully plug and play. S&S doesn't provide that on the 20+ engines.
Unless you mod the SPE to run the SNAPP filter, that's I meant. Since you ran the 1st Gen SPE with the Donaldson IIRC.
Old Oct 29, 2024 | 02:21 PM
  #49
acdii's Avatar
acdii
The second filter mount from S&S is plug and play, I don't know what the original S&S filter setup was. It is still plug and play with the S&S filter.
Old Oct 29, 2024 | 08:00 PM
  #50
Overkill2's Avatar
Overkill2
It's set up the same exact way as the 2.1 upgrade kit. I bought it and I'll take pics to show you. The SNAPP filter has the same size male SAE quick connect fittings that the 2.1 filter head has.
I could literally remove the SNAPP set up, mount the Donaldson filter head to the original mount, I'd have to double check that to see if they take the same truck mount but I'm thinking they do, and connect to the female quick connects on the hoses that are there.
You have two options: order a first use kit with bracket -- black filter with drain and black bracket or white marine version with no drain and stainless steel mount bracket... I went with the 2 micron for this.
https://ph.parker.com/us/en/product/...racor/23106-02
https://ph.parker.com/us/en/product/...acor/r23280-02
Or here's the page with all part numbers to peruse.
https://ph.parker.com/us/en/product-...eparator-racor
kenny nunez
May 16, 2022 07:43 PM
mbogosia
May 28, 2007 10:17 AM
rlh68050
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
May 9, 2006 12:03 PM
sancochojoe
Mar 10, 2005 10:52 AM
