Flywheel broken?
Old Aug 25, 2024 | 11:30 AM
rowdy89's Avatar
rowdy89
5th Gear
Flywheel broken?
I've got an 89 F250 with a 7.3 IDI and a ZF5. I recently put in a brand new napa brand clutch and flywheel roughly 4 months ago. My truck has been inoperable due to some fueling issues which I got fixed, started it up was running fine, was bleeding the lines for air when my power steering belt came loose and was hitting the fan. I shut the truck off to tighten the belt and when I went to start it again the starter engaged and spun but it just made an awful mechanical grinding noise. I climbed under the truck and put a screwdriver between the flywheel and the back of the motor, and it moves fore and aft about a 1/4 inch. I assume obviously this means the flywheel is junk. Anybody experienced this? I really don't want to drop the trans in my driveway again, but I figure I'm going to have to. When I put it in there was a consistent slight grinding noise and I now think that somehow it could have been slowly cutting itself in half? I honestly don't understand what happened and am just looking for any info, thanks in advance.
Old Aug 25, 2024 | 02:21 PM
tjc transport's Avatar
tjc transport
i ain't rite
it is possible the bolts loosened up, but either way you are gonna have to pull the trans to know what is going on.
NompNasty
May 4, 2017 11:13 PM
jakemb
15
Mar 14, 2010 09:59 AM
fomocojake1
Sep 22, 2009 09:48 AM
nd48463
Nov 30, 2004 10:02 PM
lee
Apr 30, 2002 02:22 AM
