Rubbing Flywheel
Old Nov 29, 2004 | 06:42 PM
nd48463's Avatar
nd48463
Rubbing Flywheel
I just finished installing a new motor in my 93 F-150 (302/5.0) and the flywheel is rubbing like mad! When i turn the motor over without the ignition on, it does not rub and turns fine. When I start it with the iginition, it squeels and makes a bunch of noise! I pulled the inspection plate to look at the flywheel, and It appears that one section of the flywheel (near one of the Troque converter to flywheel bolts) is freshly chewed up a bit. About 1/4 of the flywheel is chewed. After taking about 8 hours to get in the truck, I do not want to have to pull the motor again! Any suggestions on what to look for??
Thanks.
Nate
Old Nov 30, 2004 | 06:03 PM
nd48463's Avatar
nd48463
Shimmed her up
Well I remedied the squeeling flexplate problem. I shimmed the starter with a few washers and it now starts and makes no noise. I know you are not supposed to have to shim the starter on fords, but it cured the problem and seems to be alright. Bust have been a little bit different from the T-bird to the F-150. Now I just have to get her running a bit smoother. She starts and runs, but not at a good idle. I will borrow a timing light and try to get the timing straight tomorrrow.
Old Nov 30, 2004 | 10:02 PM
c_rossman's Avatar
c_rossman
flexplate on backwards?
Millam
May 21, 2015 01:41 AM
Cougar54
42
Mar 23, 2014 01:41 PM
93F150man
23
Mar 10, 2014 08:47 AM
