95 7.3 e4od no gears
Old Aug 24, 2024 | 10:56 AM
FordDuramax03's Avatar
FordDuramax03
2nd Gear
I had a problem with my 7.3s e4od slipping first gear and found a good deal on a “low mile” 97 7.3 and e4od. In the meantime I had the HPOP go out so I decided to swap them out while I had the pump rebuilt. I swapped out the trans and used the original converter with the “new” trans, fired it up and no forward or reverse gear and not even an inclination of wanting to move either way. Is there anything that could be different between a 1995 and 1997 unit? Or bad shift module? Torque converter not seated all the way? Any troubleshooting help is greatly appreciated!
Old Aug 24, 2024 | 05:21 PM
Hit Man X's Avatar
Hit Man X
Any proof the other was low mile?
Either way, a 25+ year old used trans is a fools errand as well as the used converter to me. You have two core units as far as I am concerned, sorry.
Ping Mark K and see if you can receive his input.
Old Aug 24, 2024 | 05:40 PM
TheFecalFanatic's Avatar
TheFecalFanatic
If mechanically inclined you could probably rebuild one of the E4ODs in the living room like assassin X did with his ZF5.
@Mark Kovalsky is the ford auto trans expert, he might be able to chime in with places to start looking for issues....
Old Aug 24, 2024 | 07:04 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Torque converter may not be seated properly. More likely, if it came from a junkyard it doesn't have a filter in it. Does it? WIthout a filter you won't get anything to happen.
MJboy
Aug 15, 2019 11:17 AM
86pullerf350
Aug 7, 2014 07:25 PM
70Mustang
Oct 21, 2010 02:35 PM
austin834
Jun 19, 2005 11:30 PM
Tang419
Feb 1, 2005 08:31 PM
