Windshield wiper relay- no power
Old Aug 22, 2024 | 12:12 PM
Sparking ford's Avatar
Sparking ford
4wd Low
Greetings all!...problem...2007 Ranger... windshield wipers quit working... after several days of clear weather they worked...several days later and not working again...fuses good... checked power under both relays and I have nothing....in my 1999 Ranger I have power in multiple wiper relay locations ...wipers working
Old Aug 22, 2024 | 04:55 PM
Franklin2's Avatar
Franklin2
Here are the two diagrams for your wipers 2007 ranger.
File Type: pdf
File Type: pdf
Old Aug 22, 2024 | 05:00 PM
Franklin2's Avatar
Franklin2
Looking at the 323934 diagram if you have power everywhere, I would first go out to the wiper motor plug, turn the wipers on to constant low speed, and then put the meter on the wiper motor housing and the blue/green wire. If you have no voltage I would leave the one meter lead on the blue/green wire, but move the negative meter lead to a good ground on the engine block. If you now have voltage but the motor is still not running, that means you have a bad ground to the motor. A lot of these motors are mounted on rubber mounts to reduce the noise they make and they usually have a ground strap. This strap can sometimes break and you can't even see the crack.
Old Aug 23, 2024 | 09:24 AM
Sparking ford
4wd Low
Greetings Dave F!.... Dave , I have checked every plug location at the wiper motor to battery negative and have no voltage there ....this is what led me to the 2 relays.... which I surmise should have power at one point to then send to the wiper motor when activated and the contact closes....I am going to study the prints you sent me...THANK YOU for your assistance!...
Jim King ( loooong time FORD TRUCK man!)
also owner of 15 FORD TRUCKS!
Old Aug 23, 2024 | 02:06 PM
Franklin2's Avatar
Franklin2
If you look at the diagram, the wiper motor should have a yellow wire that is hot anytime the key is on. Goes right around all those relays.
abigale.rose
Jun 12, 2022 09:38 PM
92 Black Nite
Electrical Systems/Wiring
Oct 22, 2013 07:25 AM
TheKirbyMan
Sep 10, 2010 05:43 AM
r_reed
1983 - 2012 Ranger & B-Series
Jul 4, 2008 04:04 PM
84stallion
Jul 29, 2003 04:09 AM
