wipers work half the time
Old Jul 19, 2003 | 08:00 PM
84stallion's Avatar
84stallion
i have an '84 f250 w/ a bit of a problem. the windshield wipers don't wanna work all the time. sometimes they'll work when i first turn 'em on and sometimes they don't. the times they do work, they only work for a few mins. then stop or they'll only work on high for a few swipes. i've replaced the wiper motor and switch and it still does the same thing. what the hell is wrong w/ this thing?
Old Jul 20, 2003 | 07:16 PM
Scooter29's Avatar
Scooter29
You may need a wiper delay relay, if you have intermittant wipers (no pun intended) or just the relay. Good luck and have fun....
Old Jul 21, 2003 | 04:06 AM
jdon88's Avatar
jdon88
I had a similar problem on my '80- F250, ended up being the wiper motor ground wire was loose where it connects to the cowl.
Old Jul 22, 2003 | 10:42 PM
84stallion's Avatar
84stallion
ok, i was thinking it might be the relay, only problem is that i don't know its location on the truck and i can't find the new part anywhere. anyone know itz location and where i can buy a new one...by the way the truck does have intermittant wipers... would also like to know the location of the wiper delay relay. thanx!!
Old Jul 23, 2003 | 12:51 AM
Mil1ion's Avatar
Mil1ion
The modulator/governor is usually attached to the underside of the dash just below the wiper switch.
W/Wipers have a circuit breaker.
Old Jul 28, 2003 | 03:59 AM
bmuse's Avatar
bmuse
I have the same basic problem on my86 F250, work some and stop, then slow on hi-speed only and then stop. I replaced the switch but with same results.
Is the relay/modulator is that 2"x2"x2" black box just forward/next to the wiper switch? I quess if the wiper moter was bad the wipers wouldn't work at all? When I called the parets house, they could not find and relay/modular for the wiper system.
Old Jul 29, 2003 | 04:09 AM
bmuse's Avatar
bmuse
A quick update.... I went to the Ford Parts Counter and they have the part to fix intermittent wiper problem. It is called the Wipwr Modular/Govenor...cost $125.00.
I went to junkyard, found the same part for $10.00 and it worked.
I am very happy and thanks to those that have had input on this subject that I was able to get great information to even go in the right direction. Thank You.
ALBUQ F-1
Oct 24, 2013 01:22 AM
breadstick
1997 - 2003 F150
13
Dec 30, 2012 05:40 PM
MrRogers
Oct 9, 2009 03:06 PM
wwalrus2
Electrical Systems/Wiring
Feb 10, 2003 08:39 PM
Rey
Jan 26, 2000 02:30 PM
