Front end rebuild
Old Aug 14, 2024 | 07:33 PM
Zack_Copeland556's Avatar
Zack_Copeland556
Front end rebuild
I am planning on rebuilding my steering and installing new bushings in the front axle on my 97 f250 with the ttb axle. I am looking for the best parts to use and how to fix the ttb camber. What exactly do I need to rebuild the whole front end? Any advice is appreciated.
Old Aug 15, 2024 | 12:37 AM
96SD's Avatar
96SD
Big job. I used energy suspenson poly bushings and XRF stuff from American Undercar, The camber will be fixed with bushings supplied by the guy that does the alignment. I have no idea how deep you want to go but wheel bearings and races, seals, ujoints are available through rock auto, if spindles are messed up those are available through Bronco Graveyard and miscellaneous stuff that you cant find can be bought through Torque King. I just did the job a few months ago truck drives very well.
Old Aug 15, 2024 | 09:46 AM
knottyrope's Avatar
knottyrope
once you replace one worn item, you will find the next worn item to replace
IMO, do it all at once
Been there too many times
Old Aug 15, 2024 | 08:32 PM
Zack_Copeland556
Thanks for the advice I'm planning on taking a look at everything. I don’t know if I'm going to do bearings because truck only has 138k on it. Im most likely going to just do bushings and replace most steering parts and I'm going to do the rough country 4in lift while i have the front end out.
Old Aug 15, 2024 | 08:33 PM
Zack_Copeland556
Thats my plan no point in replacing one 30 year old bushing and skipping past the others. Thanks for the advice
gatchmart
Dec 27, 2009 11:35 PM
993/4ton
1978 - 1996 Big Bronco
Apr 13, 2009 11:48 AM
camperspecial65
Jan 26, 2005 05:41 PM
jcs1966
Nov 26, 2004 11:54 AM
ranger240
Nov 16, 2003 08:15 AM
