Front End RebuilD
Old Nov 24, 2004 | 09:43 AM
jcs1966's Avatar
jcs1966
Front End RebuilD
local advanced auto cannot seem to get all the parts/bushings for rebuild. is kanters any good? i still need ream bushing right?
Old Nov 24, 2004 | 07:19 PM
66fdtrucknut's Avatar
66fdtrucknut
I know same thing happened to me, I called Auto Zone and they had everything
but ended getting them from my local ma-pa parts store. Do you still have the original one? Apparently there is diff. parts for diff. yrs. I have a 78' under mine.
Old Nov 26, 2004 | 11:54 AM
William's Avatar
William
You will need I beam and radius arm pivot bushings. I use teflon bushings for the King-Pins (no reamer needed). The meanest, most painful and frustrating part about this deal is getting the old King-pins out. Do yourself a favor and take the I Beams to a press. Reassemble the I Beams and spindles on the bench, then put them back in the truck. You will need a deep well socket 1 1/8th (I think) to get the springs out. The rest is easy. Use a good floor jack and Jack stands.
