Hello all,
I am currently dealing with my EGR and cooling core. It's lots of fun. But I am seeing some carbon buildup on the parts I have removed to get to everything. What do you recommend to clean out the carbon on the parts? Thank you so much for your attention and participation.
Any solvent will work. Gasoline or carb cleaner works well. Main thing is to ensure any small orifices or airways are clean. Larger diameter ones with some slight buildup is fine to leave as is.
