2005 crank no start
Old Jul 28, 2024 | 09:27 AM
troverman's Avatar
troverman
2005 crank no start
Note - truck has been exhibiting long cranks to start - both hot and cold - black smoke upon acceleration, rough idle especially after startup, and a small amount of surging. Otherwise - once its running - it runs OK.
New ICP valve and EGR valve within last 500 miles. New ICP pigtail. Yesterday morning did both fuel filters. Truck started after long crank; drove it 100 miles last evening. Ran and started same as before.
Unfortunately it won't start this morning. I cranked long enough for a hot electrical smell and some smoke to appear under hood.
FICM sync is good; did STC fitting last year as well as stand pipes and dummy plugs (due to a crank no start issue last summer). Tach reads a couple hundred RPM while cranking. FORScan indicates more than enough ICP pressure to start. IPR goes to 84%.
Is this an IPR problem? Can a bad IPR cause a crank no start?
My driveway is narrow at the end with stone posts and gates - wide as you go back to the garage. Of course the dead F-350 dually is right at the end. Any help on what this issue could be would be appreciated.
Old Jul 28, 2024 | 10:35 AM
runthatjunk's Avatar
runthatjunk
You need the icpv and icp numbers. If the ipr goes to 85 and stays there you likely have a leak.
Yes i it could be the ipr as well as any of the rest of of the oil system.
Old Jul 28, 2024 | 10:42 AM
troverman's Avatar
troverman
Fair enough. When I was cranking, the ICP showed higher actual pressure than what was desired. I don’t recall the exact number, but it was well above the threshold for starting. I’m suspecting the IPR isn’t functioning correctly but I wanted to know if it could indeed cause a crank no start by itself. I’d be surprised if there is another high pressure oil leak after what I fixed last year, but who knows.
Thanks for the reply, appreciate it
Old Jul 28, 2024 | 11:46 AM
BLADE35's Avatar
BLADE35
Is t.
so could the starter be damaged from all the cranking
Seems it’s cranking slow
Old Jul 28, 2024 | 11:49 AM
troverman's Avatar
troverman
Maybe what I said was misleading...its cranking fine, normal speed it always has. Starter still turns over fine after the smoke.
Old Jul 28, 2024 | 12:01 PM
BLADE35's Avatar
BLADE35
Surging is a sign of IPR blockage leaky injector or boost issue
investigate Ipr your value for its maxed out
IPR screen may have become clogged and now it’s blown screen into IPR causing no start
Check IPR% at KOEO need 14-15%
then pull inspect IPR screen and plunger
Old Jul 28, 2024 | 12:47 PM
Brotherbillstruck's Avatar
Brotherbillstruck
Sorry. Posted in wrong thread
Old Aug 3, 2024 | 11:53 AM
troverman's Avatar
troverman
IPR is out. Screen is perfect, but the larger o-ring is somewhat mashed on one side, and the small square sided oring right behind it is broken. Autozone has the Dorman kit in stock. Going to try it. Maybe pressure is leaking by, creating the long / no start. I’m hoping that’s the case because it’s a pain getting the IPR out.
Old Aug 3, 2024 | 12:00 PM
bismic's Avatar
bismic
You can get just the o-ring kit for it, part # 3C3Z-9H529-A.
https://www.tascaparts.com/oem-parts...ion-3c3z9h529a
I would recommend using a thicker lube than oil when you install it (similar to the recommendation for the standpipes and dummy plugs). A silicone grease is good.
Might also be worth heating it up a bit in oil (say 175 degrees), then wiping the oil off, applying the silicone grease, then installing.
EDIT -
Also here:
https://dieselorings.com/products/48...creen-seal-kit
Dorman is junk, don't do it.
Old Aug 3, 2024 | 02:37 PM
troverman's Avatar
troverman
Replaced the screen and orings, lubed and reinstalled. Still crank no start. Going to have to check stand pipes and dummy lugs again…scanner shows no enough ICP pressure…
Old Aug 6, 2024 | 04:28 PM
Johnny Bravo 45's Avatar
Johnny Bravo 45
If I remember correctly, your IPR values should be around 22% at idle. IPR should not be above 85% @ WOT. My HPOP was going out and I was seeing HPOP pressures @ WOT around 2000psi and IPR was reading 83%.
When I pulled my truck apart (2003 F350), I did the pressure test on the HPOP and found no leaks which helped me confirm my HPOP was the issue.
Old Aug 6, 2024 | 07:56 PM
troverman's Avatar
troverman
Thanks. My truck is a 2005 so it seems unlikely the HPOP failed, but who knows.
Old Aug 6, 2024 | 08:29 PM
Johnny Bravo 45
Just make sure you monitor everything possible to figure out the no start. I would hate to assume anything till you are able to prove it with numbers. I doubt it is the HPOP, but untill ya find the source you need to rule out all possiblities. Granted, it will not run so HPOP values are not all accessible. It will be interesting to see what you find on the leak test.
Hope the best for ya and I pray ya find the problem quickly!!!
Old Aug 7, 2024 | 04:11 AM
troverman's Avatar
troverman
Thanks, appreciate it.
beercake
Aug 13, 2020 01:43 AM
GOODOLEF250
17
Jun 22, 2019 04:52 PM
Trucky2
Sep 23, 2010 06:33 PM
dusred
Dec 1, 2009 05:27 PM
jlsdcen2
2004 - 2008 F150
Oct 20, 2009 12:02 AM
