Sponsored by: Auxito
Battery terminal issues
Old Jul 23, 2024 | 09:13 AM
waldo16's Avatar
waldo16
When I bought my truck it had a broken negative terminal that would have to be held by pliers so it would tighten around the post to start so I replaced it with a new one but it still has issues with starting and I have to take the terminal off and on and mess with it. Any suggestions on what it could be? It’s a 97 XLT model.
Old Jul 23, 2024 | 10:45 AM
Jon Freeman's Avatar
Jon Freeman
Have you tested the battery? Perhaps with the grounding issues it's not recharging properly.
Old Jul 23, 2024 | 11:03 AM
waldo16's Avatar
waldo16
Yes I have, I took it to O’Reillys and both my battery and alternator are good. I’ve been thinking it’s the negative cable or just a bad ground but I haven’t checked yet
Old Jul 23, 2024 | 12:04 PM
RLXXI's Avatar
RLXXI
The battery cables are notorious for getting corrosion inside the sheath where you can't see it and can cause your concern. Try this, make sure you have both cable ends secure and clean and take a standard 12v test light and poke thru the cable insulation a few inches from the battery. If the light goes out or gets real dim when trying to crank the truck, the cable is bad.
Old Jul 23, 2024 | 12:24 PM
Hit Man X's Avatar
Hit Man X
Standard Motor Products (SMP) on Cockauto make nice, properly fitting batt cables for a modest cost. The neg is about $25 shipped w tax. Use that 5% off code they have.
If you swap it, clean all the positive terminals while apart
Old Jul 23, 2024 | 07:56 PM
steve(ill)'s Avatar
steve(ill)
You can have a THIN BLACK CORROSIVE coating on the battery terminal or the inside of the clamp... Not the green gooey stuff you normally see... Take a wire brush or 60 grit sand paper and SCRUB the terminal and inside the clamp until you see SILVER/ lead color... then reinstall.
Old Jul 24, 2024 | 07:49 AM
waldo16's Avatar
waldo16
Found the issue!
Old Jul 24, 2024 | 07:53 AM
RLXXI's Avatar
RLXXI
Originally Posted by waldo16
Found the issue!
Bingo!
Old Jul 24, 2024 | 08:34 PM
Hit Man X's Avatar
Hit Man X
Is that stock main ground point?
Old Jul 24, 2024 | 08:50 PM
waldo16's Avatar
waldo16
I have no clue lol, I traced the cable from by battery to the frame and found that corroded piece connected on my starter
Old Jul 24, 2024 | 09:08 PM
Hit Man X's Avatar
Hit Man X
Fair enough.
Old Jul 25, 2024 | 04:14 AM
RLXXI's Avatar
RLXXI
That is the stock mounting location for the ground cable.
Old Jul 25, 2024 | 12:45 PM
Hit Man X's Avatar
Hit Man X
Excellent, thank you!
NickChallis92
Feb 22, 2024 01:45 PM
Mcsneezy
Feb 15, 2024 09:17 AM
chazsamuel2900
6.4L Power Stroke Diesel
Mar 21, 2022 11:50 PM
bostergard
Aug 9, 2009 12:13 PM
Bobtailfan
Electrical Systems/Wiring
Sep 7, 2004 09:50 PM
