Sponsored by: Auxito
'01 F150 4.6 Engine replacement *Code ID* *HELP*?
Old Jul 25, 2024 | 02:35 PM
Solace667's Avatar
Solace667
1st Gear
I have a:
01 F150 XLT 4.6L 4x4 automatic
I'm installing a new motor in.
The VIN is: 1FTRX18W51NB8xxx, which reflects an '01 4.6L 2v Romeo: - which,, i understand should have a PI engine after the '00 model year; & is OE specced for a DFZK engine, which apparently had 2 configurations for this 7/2001 model.
- but the engine & trans had been swapped before I got it;
- & the intake, head, & valve cover codes don't seem to match up with the year/make/model of the truck.
I *need help* identifying what I currently have in there; with the hopes of having purchased a new long-block engine that will align correctly with the newer transmission, existing intake, comp program, harness, & sensors;
- & ideally with correct PI configuration.
The upper Intake is cast aluminum,
stamped: 1L3E-9424-BA
The head is stamped on the drivers side rear,
above the exhaust manifold: S73
RF-F5AE-6090. B24A;
- with a circular 'wagon-wheel' stamp on the left that has '97' in the middle.
The Driver's side valve cover sticker reads:
?C2E-6A505-CC. M03
Please can anyone tell me what i might be looking at,, & if ill have any problems installing a *PI*
DFZK 2v Romeo 4.6 long block in its' place?
Is there more info I need to provide to determine this?
I can provide more pics on request...
Thanks!
\"Triton 4.6L" intake cover & plenum removed.
Driver's side rear, above exhaust manifold.
Upper intake manifold casting code, driver's side rear.
Driver's side valve cover ID Tag
keepsgoing4evr
1997 - 2003 F150
Apr 10, 2024 12:59 PM
cope652
Large Truck
Jun 5, 2021 01:24 PM
lastoftheairplan
27
Oct 17, 2019 12:08 PM
Oldschoolcarguy
Modular V8 (4.6L, 5.4L)
Dec 12, 2017 01:24 AM
zxcy38462
Aug 16, 2015 05:23 PM
