Noisy Speedometer
Old Jul 12, 2024 | 02:32 PM
arthall's Avatar
arthall
Noisy Speedometer
I have a 53 F100 with the 239 flathead V8. It has been sitting still except for a couple of recent driveway miles since 1967. When I took it for a test drive the first time and got up some speed, I heard a noise that sounded like it was coming from under the dash. Also, the speedometer needle was bouncing all over the place. I bought and installed a new speedo cable but there was no change. I then cleaned and modified the old cable so I could drive the speedo with a drill, while sitting still. Same noise and bounce, but maybe a slight bit less. So, I guess it is in the speedo. The question is, is there any way to lube the speedometer internals? Maybe an oil port? What's the best way to lube the new cable? Also, if I keep running it with the drill, I wonder if it will loosen the effects of sitting unused or 57 years? And ideas will be appreciated. TIA
Old Jul 12, 2024 | 05:24 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
There is an oil port in the top where the cable goes in. There is a bushing there. It takes a few drops of 3-in-1 type oil, or clock oil.
Old Jul 12, 2024 | 05:26 PM
arthall's Avatar
arthall
Thanks! I will look for that.
Old Jul 13, 2024 | 08:40 AM
fordf348's Avatar
fordf348
Does anyone know if the 1948 speedometer has a port to lubricate it?
Old Jul 14, 2024 | 06:14 AM
fh4ever's Avatar
fh4ever
This is new to me! Does the '51 have one?
Old Jul 14, 2024 | 09:01 AM
JPMallory's Avatar
JPMallory
It's been a long time since I've had mine out, but I believe that it does.
Old Jul 14, 2024 | 12:12 PM
fordf348's Avatar
fordf348
I don't want to take it out unless I know for sure
Old Jul 14, 2024 | 12:24 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You shouldn't have to pull the speedo to oil it, if you have something like this. It only needs a couple of drops.
Old Jul 21, 2024 | 01:02 PM
roadrunner01's Avatar
roadrunner01
I use John Deere chain & cable lube and it quiets the cable and speedometer
bajafishnut
Jan 26, 2017 03:23 PM
Connecticut Calvin
Sep 13, 2016 12:05 PM
alconk
Apr 18, 2009 11:33 PM
Stanstruck
Dec 4, 2004 08:51 PM
