noisy speedometer.
Old Dec 4, 2004 | 11:38 AM
Stanstruck's Avatar
Stanstruck
noisy speedometer.
My speedometer has started being noisy. What can I do beside replacing it? If I remember correctly we took off an old chebby cable once and poured some graphite down the cable. Is this an option?
thanks,
Stan
Old Dec 4, 2004 | 12:02 PM
RR4E's Avatar
RR4E
Graphite is the normal choice for speedo cable lube, and it might help. Give it a try and let us know if it worked. Is it bouncing, or showing off-speed from normal?
You may also want to remove it from the housing, and check the drive gears inside the speedo. If they are wearing, adding some white grease might save them for a bit, but it's going to be time for a trip to the wrecker soon if this is the case.
Old Dec 4, 2004 | 06:33 PM
Stanstruck's Avatar
Stanstruck
Thanks RR4E. It's chattering/bouncing. I'll try the suggestion and it sounds like I should pull the speedometer out of my parts truck while I still have it.
(...just in case..)
Stan
Old Dec 4, 2004 | 08:51 PM
Double T Dave's Avatar
Double T Dave
Question Mine is doing it too.
Let me know if it works. Mine is doing the same thing. My odometer is jumping up and down and making allot of noise.
