Trans Fluid change- need advice
Old Jul 8, 2024 | 09:48 PM
mtnbkr738!'s Avatar
mtnbkr738!
Trailering
Hi all
2021 f250 gasser 4x4
Im used to changing trans fluid on my Chevy 2500HD. I'm used to disconnecting the transfluid cooler line up by the radiator and turning on the engine and pumping out all the Old fluid until the new stuff comes through... so i get a pretty good "flush" of the old stuff out.
with that said, Is that the similar process on my 21 f250??? Ie: disconnect the lower line and run the engine until the new fluid pumps out of the line????
OR is there an easier or different way to flush all the old stuff out of the lines??
thx thx thx!!!!
Old Jul 9, 2024 | 04:25 PM
Rich1961's Avatar
Rich1961
@mtnbkr738! Take a look at this video.
Old Jul 9, 2024 | 09:24 PM
mtnbkr738!'s Avatar
mtnbkr738!
Trailering
Thats diesel. Different trans. But thx!!
Old Jul 10, 2024 | 08:35 AM
WXboy's Avatar
WXboy
You've got to change the filter or you're doing yourself no good. Drop the pan and change the filter, then refill with fresh fluid. Probably should do this every 50k miles or so if you plan to keep the truck forever.
Old Jul 10, 2024 | 10:42 AM
cpobst's Avatar
cpobst
I just did my 2022 6.7. Definitely drop the pan and change the filter as previously stated. I replaced my pan with one from PPE not for the additional capacity but so that I would have a drain plug.
Old Jul 10, 2024 | 12:37 PM
mattymax's Avatar
mattymax
I did the same with the PPE pan on my 2019.
Drop pan and filter change on a regular basis will keep you good. No need for a flush unless it goes undone a while. “Regular basis” is gonna be up to you.
Old Jul 10, 2024 | 03:40 PM
mtnbkr738!'s Avatar
mtnbkr738!
Trailering
yes i AM dropping the pan and changing the filter.... THATS NOT THE QUESTION
LOL!!!
the question is HOW TO FLUSH /DRAIN THE FLUID OUT OF THE TRANS COOLER???
Old Jul 10, 2024 | 09:15 PM
Bugzilla46310's Avatar
Bugzilla46310
Watch the Amsoil video posted above. He does it
medic503
Jul 12, 2013 11:52 AM
buckaroo2219
Mar 27, 2011 07:21 PM
rpatrick
13
Mar 18, 2007 10:16 PM
Americanmadeford
Jan 28, 2007 07:54 AM
MikeSDK
Jul 8, 2006 05:35 PM
