E4OD Fluid Change
Old Jan 26, 2007 | 07:34 PM
rpatrick's Avatar
rpatrick
E4OD Fluid Change
Guys,
Decided to change my own tranny fluid. I plan on dropping the pan and changing the filter, then draining the converter.
But what about the fluid in the lines and radiator? Should I try to blow this our or is this not enough to worry about?
Reason I ask is that the last time I changed the fluid, I only got about half of it out.
Also, what's the best brand of Mercon to use? Do the E4OD's have a preference?
Thanks,
Rob
Old Jan 26, 2007 | 07:54 PM
Bear1_301's Avatar
Bear1_301
fluid change
Here's a link, hope it helps?
http://www.7point3.com/Writeups/TransFlush.aspx
Old Jan 26, 2007 | 09:17 PM
rpatrick's Avatar
rpatrick
Perfect - thanks, Bear.
Old Jan 26, 2007 | 09:39 PM
quicklook2's Avatar
quicklook2
get trans. filter from ford, get a lot of trans. fluid if you are going to flush the lines.
if the trans fluid is not real burnt i would not mess with the very small amount in trans lines.
add a bottle of lucas trans fluid.
Old Feb 8, 2007 | 11:37 AM
rpatrick's Avatar
rpatrick
Well, I finally got around to changing the fluid. Dropped the pan, re-installed Ford filter and flushed everything through the return line method linked above.
It made a HUGE difference - it is a LOT quieter and the shifts are a TON smoother. I guess it degrades slowly over time and you get used to it and don't notice how badly the transmission is behaving.
The only thing it didn't fix is the shudder - it seems a little better but it's still there. I'll add a tube of Dr. Tranny's Shuddre Stop and see if that clears that up.
And I highly recommend the linked flush method. I did the Expy a few weeks back using this and after doing it twice I think I got out WAY more of the old fluid with a lot less work.
Old Feb 8, 2007 | 11:44 AM
quicklook2's Avatar
quicklook2
did you add lucas trans. fluid for one of the quarts?
lucas and new fluid fixed shudder in one truck and the next time i used lucas, shudder fixx and new fluid and no more shudder.
Old Feb 8, 2007 | 11:46 AM
Bear1_301's Avatar
Bear1_301
Smile Fluid change
Glad that helped you. I don't recall the post you made about the shudder? I put a can of trans-x in mine when I changed fluid & after 1000 miles the fluid is still red.
Old Feb 8, 2007 | 11:57 AM
quicklook2's Avatar
quicklook2
the post earlier in this thread i suggested lucas.
i have posted how to change the fluid and what to put in at least 20 times in past posts.
it is amazing what a difference new fluid makes.
Old Feb 8, 2007 | 05:51 PM
rpatrick's Avatar
rpatrick
I didn't add anything to the fluid yet. I figured that before I tried anything I'd see if fresh fluid would fix all the ills.
Since it didn't and the tranny is now full, I figured I'd try the Dr. Tranny shudder fix first. Since it is only a small tube, I won't have to suck out any of the new fluid. I filled it all the way to the top of the fill range - I would not want to pour another quart in unless I pulled some out. That's why I didn't try the Lucas.
I love the look of red oil on a tranny dipstick .
Old Mar 18, 2007 | 09:49 PM
str8racing's Avatar
str8racing
[QUOTE=Bear1_301]Here's a link, hope it helps?
http://www.7point3.com/Writeups/TransFlush.aspx[/QUOTE] this is ok for the e40d? it says 4r100. also what trans fluid is recommended , mercon? and lucas?
Old Mar 18, 2007 | 10:06 PM
quicklook2's Avatar
quicklook2
how to do a flush and fluid change and what to use covered many times, do a search.
Bear1_301's Avatar
Bear1_301
Mercon is fine. Ford definatley says NOT to use Mercon V in the E4od.
Old Mar 18, 2007 | 10:10 PM
str8racing's Avatar
str8racing
i did find the flush in search, but was not sure if it was for e40d and what trans. fluid to use.
Old Mar 18, 2007 | 10:16 PM
Bear1_301's Avatar
Bear1_301
The flush procedure is basically the same for both trans.
Island Time
15
Oct 7, 2014 12:11 PM
AF_MAC
Jul 5, 2014 06:45 PM
davidwags3
Jan 20, 2014 10:22 AM
f1501987
Nov 24, 2012 10:58 PM
71mustang
Aug 3, 2002 10:22 AM
