Desperately Seeking knowledgeable advice
Old Jun 28, 2024 | 12:17 PM
Sindee's Avatar
Sindee
1st Gear
Can someone please point me in the right direction I don't even know where to begin I have been dealing with this truck issue for well over a year and I just keep getting the runaround from so-called friends that say they know how to work on the vehicle so it appears that I'm going to have to do this myself so I need some direction where to start or what to do. Any help would be greatly appreciated.
Old Jun 28, 2024 | 12:37 PM
Ted722's Avatar
Ted722
Welcome aboard, I'd start out by describing the issue you've been dealing with this last year. Also, searching the issue works too. I've had the best result with searching using google, then appending ford fte at the end (example: 2004 Ford F150 spark plug torque ford fte)
Edit: Did not originally see diagnostic sheet attached
Check out the tech folder in this forum too: https://www.ford-trucks.com/forums/8...pful-info.html
Grab a manual to get to know your truck better (often on sale at your local auto store): ie....https://haynes.com/en-us/ford/f-150/2004-2014
Old Jun 28, 2024 | 08:42 PM
Johnny Paycheck's Avatar
Johnny Paycheck
Just a hunch FWIW…
Ignition coil circuit malfunctions, causes misfire and O2 sensors detect raw fuel in exhaust, computer adjusts to other extreme and is stuck in lean running condition.
Some discussion here:
https://www.f150forum.com/f4/p0351-e...522820/index2/
Old Jun 28, 2024 | 09:57 PM
Ted722's Avatar
Ted722
Some good overview plus a vacuum leak find:
Old Jun 29, 2024 | 12:03 AM
Papa Tiger's Avatar
Papa Tiger
The first sensor screwed into the Catalytic muffler from the motor is the bad code and the one to replace..
Your Muffler people can give you good advise about replacing the Catalytic muffler and both Sensors.
The lower 2 codes are secondary. Do you need a Tune up? Your mileage is representative of new Catalyst muffler and Sensors screwed into it + tuning up the motor too.
Flyct
2015 - 2020 F150
Apr 15, 2024 07:12 PM
GaBilgerat
May 21, 2023 07:20 AM
Isa
2015 - 2020 F150
Sep 27, 2021 09:24 AM
blurgonesnow
Sep 4, 2021 10:07 AM
Jeff Pauley
Large Truck
Apr 28, 2021 07:38 PM
