Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
I need numberdummys help!!
Old Apr 27, 2021 | 03:47 PM
Jeff Pauley's Avatar
Jeff Pauley
I need help decoding this please. Thanks
Old Apr 27, 2021 | 08:02 PM
85e150's Avatar
85e150
Welcome to FTE!
F60 = F600 gas 4x2
D = 330 2V HD FT gas V8
C = Ontario Truck Plant
B63137 = 1967 series number
174 = 174 inch wheelbase
J = Red
F602 = F600 gas 4x2 20,000lbs GVWR
481 = I don't have the complete info for upholstery, seat type etc., or cab type in all cases. My guess here is standard cab.
A = New Process model 435 four speed transmission
62 = Timken model F106N Single Speed Rear Axle / 6.20-1 / 15,000 lbs. Rear Axle Capacity.
No front axle code. In '64 to '69 codes appeared only for optional front axles. Otherwise, it's a Ford standard axle, most likely 5,000lb capacity.
20000 = 20,000lbs GVWR
164 3800 = 164 certified net HP @ 3800 RPM
41 = Chicago District Code
If something doesn't match, let me know and I'll double check.
Old Apr 27, 2021 | 08:12 PM
Jeff Pauley
Thank you very much. The truck has a shifter with the split rearend option but it could have been installed after factory for sure. And it has a f500 hood which threw me off to. The engine was the main thing I needed info on. I really appreciate your help.
Old Apr 27, 2021 | 08:25 PM
yardbird's Avatar
yardbird
Does the speedometer show the correct speed in both high and low range, or show very fast in one range and correct in the other? If so, that pretty much tells you the axle was put in later. Very few people went to the trouble to put in the speedometer cable range splitter when adding a two speed rear.
Old Apr 27, 2021 | 08:37 PM
Jeff Pauley
Im not sure as we just got it running after sitting in a barn for several years. Its supposedly an old state road truck. Its in good shape for the year.
Old Apr 27, 2021 | 08:49 PM
yardbird's Avatar
yardbird
If you get a chance, post some pictures of it. We all love pictures of trucks.
Old Apr 27, 2021 | 08:52 PM
Jeff Pauley
You got it. Thanks for everyone's help.
Old Apr 27, 2021 | 11:47 PM
85e150's Avatar
85e150
You good on the two speed? There are Eaton videos available, as well as the "short version". It's important NOT to shift one going downhill.
Old Apr 28, 2021 | 02:48 PM
Jeff Pauley
Yes sir. I appreciate you asking tho. Could be a costly mistake for sure.
Old Apr 28, 2021 | 07:31 PM
Hillbillysuv's Avatar
Hillbillysuv
Yup. Learned never to do that again when borrowing my grandpa's dump truck back in the 1990s. I tried to shift the differential going down a 6% grade with a bunch of switchbacks. Fortunately I was able to get it stopped. If I'd had a heavier load on it, I'd have been in trouble.
Old Apr 28, 2021 | 07:38 PM
85e150's Avatar
85e150
I know the feeling. I fumbled a main trans downshift on an offramp....made it. I was wondering how I would replace my dads truck if I survived.....
mechmagcn
Arkansas Chapter
Oct 16, 2017 07:25 PM
Curated Content Editor
General Automotive Discussion
Jun 26, 2017 03:56 PM
superduty4x4
Dec 3, 2010 12:46 AM
48fordcoe
13
Oct 11, 2009 09:22 AM
