1956 F250
Old Jun 30, 2024 | 02:54 PM
52 Merc's Avatar
52 Merc
Originally Posted by dmaj111
so is there a coupling in the shaft housing to break apart so i can have a new gear box pressed on or do i take the entire shaft and box to the shop?
There is no coupling. The steering shaft and worm gear is one piece. It may be able to be serviced and the gear replaced with aftermarket parts, but the original part was serviced from Ford as one piece, shaft and worm gear together, basic part number 3524 in the diagram below.
Old Jul 5, 2024 | 08:10 AM
dmaj111's Avatar
dmaj111
still having issues finding a box i have found this one on EBAY just now. Does this make sense to try?
Classic Performance steering box Vega Saginaw manual 25-1 gear ratio
i have been seeing these but unsure of fit even tho it SAYS so.
Old Jul 5, 2024 | 11:40 AM
bigwin56f100's Avatar
bigwin56f100
it's been 30 yea since I've heard anyone talk about a Vega steering box in a 53-56 ford truck. Definitely better choices than the Vega
Old Jul 5, 2024 | 03:09 PM
56panelford's Avatar
56panelford
Wouldn't a Vega box be pretty light duty for a F250..?
Old Jul 5, 2024 | 07:13 PM
52 Merc's Avatar
52 Merc
The Vega steering box was/is a popular replacement for lighter weight street rod applications as it gives options for cross steering, compactness, steering shaft options and making more clearance for custom engine and exhaust. In a truck, I'd stick with rebuilding the stock box or stepping up to the CPP/Toyota if power steering is desired.
Old Jul 6, 2024 | 08:13 AM
dmaj111's Avatar
dmaj111
sounds like i am back to square one. The girls named the truck "the Stubborn Mule" because of all the setbacks. we just kept going fighting it thru
Old Jul 6, 2024 | 10:52 AM
dmaj111's Avatar
dmaj111
Retired here so on limited budget as usual. I need to repair / replace manual steering gear box. Would it be cost effective to install power steering or should i stay with what i have?
I am now looking at a complete power steering kit they said I must cut the steering shaft off and install steering universal joint included it appears I just need a belt as pump, bracket, and hoses are included. It is expensive so I have to sell my grandsons
Glxy66
Apr 29, 2012 08:27 PM
gonzo
22
Feb 18, 2007 10:02 PM
Levergun
Mar 22, 2004 11:15 AM
michaelgordon@attbi
Jun 10, 2003 11:58 AM
