Oil leak
Old Jun 24, 2024 | 09:56 PM
JKBrad's Avatar
JKBrad
Oil leak
I guess I.m not driving my truck enough anymore. I had a pretty decent leak lately, from the vacuum pump. I changed that after it got pretty bad and the leak went away. I cleaned the entire area underneath as well as I could, then changed the oil. Now, I notice an oil stain with a drip at the bottom of the engine where the oil pan/engine meets the transmission. the oil drips onto the sway bar too, but nothing drips on the garage floor...yet.
I've cleaned the area twice, hoping that oil was still dripping down from the vacuum pump mess. I also changed the PCV valve, in case the old one was creating high pressure in the block. I've carefully checked higher and it's all dry, just wet at the place described above. I really hate to do this job without a lift and trans jack. It's really easy to do once you get to it though. I'm going to check the back of the valve covers first, but I see no evidence of a leak coming from higher up. I may just have to bit the bullet and take it to a local shop.
The truck only gets driven about 2500 miles a year in the last couple years. It has 69k miles on it. The vacuum pump and this are the only real issues I've ever had with it.
So, anyone had to deal with this yet? Any tips, tricks or advice?
Old Jun 25, 2024 | 06:56 AM
Olds64's Avatar
Olds64
You might try to simply tighten the oil pan bolts. That's weird that you found the oil pan leak right after changing the vacuum pump.
Old Jun 25, 2024 | 11:35 AM
JKBrad's Avatar
JKBrad
I noticed oil in that area first, that's when I discovered the vacuum pump leaking bad. I figured that was the problem. Once I had it all cleaned up, I noticed that there was still oil at the bottom of engine. After cleaning the area a couple of times, it's clear that there is a leak in that area. Everything around the pan is dry, the only oil found seems to be coming from the rear main.
Old Jun 25, 2024 | 01:07 PM
PupnDuck's Avatar
PupnDuck
IF you're talking about the 3,5 EcoBoost and IF you're dealing with an engine oil pan that's stuck on with silicone rather than a gasket the worst thing you could do is tighten the pan bolts.That will guarantee major oil leaks. I'm on my third oil pan (all replaced under warranty) in 50K and it's leaking again.
Old Jun 25, 2024 | 01:46 PM
JKBrad's Avatar
JKBrad
It’s a 3.5 EB, but it has an aluminum oil pan from the factory.
Old Jun 26, 2024 | 10:41 PM
JKBrad's Avatar
JKBrad
Yesterday, I took it to the car wash and really got the wand down into the area behind and below the vacuum pump. I was thinking that since it was leaking so bad that there could be some crud back there that would start to run oil off of it when it gets hot. I cleaned the engine bay and the bottom end really well. Afterward, I gave it good run down the highway for about 5 miles.
I parked it in the barn, left the hood up and let it sit for 24 hours. Went out tonight and it was all dry down there, no oil at all. I'm going to be cautiously optimistic about it, then recheck it after the next time I take it out for a good long drive. At the very least, my engine is really clean now.
Old Jun 27, 2024 | 06:42 AM
Olds64's Avatar
Olds64
Hopefully it isn't leaking anymore.🤞
Good point about the sealant used on the oil pan. I forgot that the 3.5l EBs already have oil pan issues.
Old Jun 27, 2024 | 08:05 AM
JKBrad's Avatar
JKBrad
There is a way to convert yours to an aluminum pan. It’s a process though, but probably worth it.
Old Jun 27, 2024 | 11:51 AM
PupnDuck's Avatar
PupnDuck
Been down that road with the dealership service manager. According to Ford, if you want the problem fixed under either the original or my Ford ESP warranty, they have to follow the TSB which mandates a plastic pan and silicone slop. If I want it converted to a metal pan I have to pay for it 100% out of pocket. Since I'm on my third plastic pan (soon to be fourth) I have to wonder just how much money Ford has saved by being idiots.
Old Jun 27, 2024 | 12:49 PM
GlueGuy's Avatar
GlueGuy
With 60K miles on a 9-year-old 2015, I wonder which route I'd take? Mine's been an easy keeper, and at the rate I'm going it could last another 9 years. Sure, if it started leaking, I'd go for the aluminum pan.
Mikethetrucker
Oct 19, 2024 08:50 PM
bravovictor
6.7L Power Stroke Diesel
22
Jan 16, 2024 10:12 AM
JKBrad
2015 - 2020 F150
Jan 21, 2023 08:25 AM
bomberopm
Feb 5, 2007 09:50 PM
Blondie40
1997 - 2003 F150
Dec 17, 2001 02:15 PM
