Sponsored by: Auxito
Oil Leak
Old Aug 30, 2001 | 07:41 AM
Blondie40's Avatar
Blondie40
Oil Leak
I own a 1999 F-150 super cab,4x4,5.4,approx. 31,250 miles. Over the last several weeks I've been smelling oil every time I get out of it, even when I only travel a couple of miles. I've had the engine steamed cleaned and we can't find any signs of a leak, there's nothing under the vehicle when I move it and the oil level is fine. However there is still a very strong odor of oil when ever I drive it. Any ideas what might be going on?
Old Aug 30, 2001 | 02:56 PM
Deebo's Avatar
Deebo
Oil Leak
There is a leak some where. Probably a valve cover. The oil is leaking on to the exhaust manifold and burning off. That's probably why no oil is seen on the ground.
Old Aug 31, 2001 | 07:15 AM
Blondie40's Avatar
Blondie40
Oil Leak
Thanks for the advice Deebo, I'll take a closer look.
Old Sep 3, 2001 | 09:54 PM
RSOsborne's Avatar
RSOsborne
Oil Leak
A friend had the same problem with his 99 Exp w/5.4 at around 35K miles. It turned out to be leaks between the block and heads. The deck of the block had a course finish and the headgasket would not seal. The fix was a new long block at Ford's cost. He advises - twist every arm you can until they fix it.
Old Sep 4, 2001 | 09:57 AM
2fulhunden's Avatar
2fulhunden
Oil Leak
i have a 99 f-150 that has an oil leak since 18,000 miles. ford has replaced the head gaskets twice and it still leaks. right now it has 29,500 miles on it and the warrenty is up pretty soon and they still won't replace the motor. does any body know if this is pretty common with this motor or what..
Old Dec 17, 2001 | 10:50 AM
Brett99's Avatar
Brett99
Oil Leak
>what..
Hello Everyone,
I have a 99 F-150 5.4 oil leak. I had the head gasket replaced at 29000 and now I'm bringing it back for the same thing @ 37000. I should still be cover under the 12,000 or 12 month service warranty. Has anyone heard of a recall on this? I want some ammo when I drop it off at the dealer for repair. Thanks for your insight.
Brett99
Old Dec 17, 2001 | 02:15 PM
pilot10's Avatar
pilot10
Oil Leak
bangbacj7
53
Jun 13, 2013 07:51 PM
abubba1
6.4L Power Stroke Diesel
23
Jan 1, 2013 12:23 PM
Randallman
Modular V10 (6.8l)
25
Dec 5, 2012 06:33 AM
olboney17213
Mar 4, 2009 07:41 AM
fairlaniac
Jun 13, 2005 01:05 PM
