Need help deciphering live data file
Old Jun 26, 2024 | 08:09 AM
Da_Coonass's Avatar
Da_Coonass
Originally Posted by Sous
I noticed your MAP PID did not report any data, but it was also logging in Hz instead of PSI. I would start by checking to make sure the MAP sensor is working. On a cold engine, with the engine off and ignition on, EBP, MAP and BARO should be within .5 PSI of each other. The odd ball is suspected bad and should be replaced or troubleshot.
Charted data is pasted below and chart is attached.
BARO, MAP and EBP are all basically the same one was .1 % different.
Old Jun 26, 2024 | 08:15 AM
Da_Coonass's Avatar
Da_Coonass
Originally Posted by BWST
Definitely can see your rough idle there. Here is a comparison between your file and one from my truck. The vertical scales have been adjusted to better see the data:
Air in fuel is a good thing to rule out.
Does the idle smooth out if you unplug the ICP sensor?
If not, the next thing we recommend is to clean/reseal the IPR valve, or replace it with a Motorcraft part from a reputable seller. That part has a large effect on idle quality.
no noticeable change when unplugging the ICP. I will get a new IPR coming ASAP. I noticed the pigtail for the IPR was greasy so I’ll replace that as well. Thanks again.
Old Jun 26, 2024 | 09:09 AM
udsuth78's Avatar
udsuth78
If the solenoid is still good the IPR valve can be disassembled and cleaned fairly easily. Here's a couple vids showing how it's done.
and
Honestly though, based on your ICP and IPRDC% numbers I'd be surprised if cleaning or replacing the valve would have much of an effect. The air in fuel would be a more likely suspect based on the numbers. Whatever you do, don't throw away the old valve if you do decide to replace it.
Old Jun 26, 2024 | 09:34 AM
Da_Coonass's Avatar
Da_Coonass
https://www.youtube.com/watch?v=vEWVURhDt-Q
and
https://www.youtube.com/watch?v=fzdRwjo4pbY
I ordered an IPR and a rebuild kit. Gonna install the new one and rebuild the old one and hang on to it.
Old Jun 29, 2024 | 02:51 PM
Da_Coonass's Avatar
Da_Coonass
Ok fellas I got the proper BT dongle and replaced the IPR and pigtail. The behavior of the truck is much better. Throttle response is crisp and I picked up 3.5 mpg. BUT i still have a rough idle. I have made another data log of a 1 min idle with new dongle and will post it here as well as the codes from the PCM. I appreciate any help you boys give.
File Type: csv
Old Jun 29, 2024 | 03:09 PM
BWST's Avatar
BWST
Got Data?
Your idle is showing smoother than last time, but IPR% is lower than normal, and PW is higher than normal. It's acting like a counterfeit IPR. Where did you buy the IPR, and what brand did you purchase?
Old Jun 29, 2024 | 03:13 PM
Da_Coonass's Avatar
Da_Coonass
Your idle is smoother, but IPR% is lower than normal, and PW is higher than normal. It's acting like a counterfeit IPR. Where did you buy the IPR, and what brand did you purchase?
Riff Raff. Motorcraft IPR. Alliant pigtail
Old Jun 29, 2024 | 03:16 PM
BWST's Avatar
BWST
Got Data?
Darn, ok, that's a strange one. Gotta research this some more.
Now that you have the new dongle, would you capture a WOT run from 0 to 60mph through the gears, and post that file?
Old Jun 29, 2024 | 03:19 PM
BWST's Avatar
BWST
Got Data?
Your VPWR is sitting at 12.5V. The engine shows warmed up, so thinking the glow plugs should not be on. What do you measure at the batteries for voltage when the engine is idling?
Old Jun 29, 2024 | 04:06 PM
Da_Coonass's Avatar
Da_Coonass
13.4 V idling
Old Jun 29, 2024 | 04:08 PM
Da_Coonass's Avatar
Da_Coonass
so on the 0-60 run…. Do I literally hit record then hold it to the floor till I reach 60?
Old Jun 29, 2024 | 04:15 PM
BWST's Avatar
BWST
Got Data?
That’s right. Or, you can hit “play“ and it will begin recording in your driveway and then you can drive to where you want to do the wide-open throttle run. That normal driving data can sometimes be helpful. Then do your wide-open throttle run where it’s clear and safe. You can keep it recording and drive home and hit stop, save the file as a CSV and send it to us
Old Jun 29, 2024 | 05:05 PM
  #28
Da_Coonass's Avatar
Da_Coonass
I feel like this file is not usable
Old Jun 29, 2024 | 07:25 PM
  #29
BWST's Avatar
BWST
Got Data?
would you also unplug the ICP sensor and record a one minute idle? I want to see if the pulse width goes back to normal at least. i’m wondering if the ICP sensor has a bias to it. Could you post a picture of it? Want to check if it’s OEM.
you might’ve said this already, but is the ICP sensor connection dry – no oil in it?
Old Jun 29, 2024 | 07:59 PM
  #30
BWST's Avatar
BWST
Got Data?
That's a good file you posted. The PID charting tool in Excel will take the whole thing, and one can scroll to the interesting parts. Here is your WOT run. For a stock truck, it looks good to me:
ICP is 2800psi, IPR% commanded 35% and level, normal WOT PW of around 3ms. Boost (MGP) is 15psi. APP% is 75, which is a typical pedal-to-the-floor reading.
