Ground cable 223 ci
Old Jun 17, 2024 | 09:23 AM
ADELEANDRE's Avatar
ADELEANDRE
Ground cable 223 ci
Hi guys,
Can anyone tell me if there is a ground cable between the body and the engine block on a 223 and where is it attached ? I don't think the block takes the ground by the engine supports ?
Old Jun 17, 2024 | 12:21 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Probably. It is likely shown somewhere in the shop manual. But you can always add a redundant one. I’m not familiar with the 6 cylinder engine location. You can just run a heavy cable from the firewall to engine block, one from block to the frame, that’s what I did on my previous 59 F250. Any further grounding/bonding issues would be related to poor connections at the individual loads, a common problem
Old Jun 18, 2024 | 01:27 AM
ADELEANDRE's Avatar
ADELEANDRE
Thanks, it's because my truck is partially dismantled and I didn't see this info on the workshop manual. I'm going to look at the engine block, there should be a thread to screw in a bolt to put in a ground wire.
Gee150
Sep 1, 2020 09:51 AM
bmarsh
Nov 17, 2012 07:11 PM
DBrawley
Nov 14, 2011 05:10 PM
r9wolves
Electrical Systems/Wiring
Jan 31, 2005 10:37 AM
slntnddly
Dec 22, 2003 06:40 PM
