7.3 IDI E4OD Stand Alone Computer
Old Jun 16, 2024 | 12:51 AM
KJ_825's Avatar
KJ_825
1st Gear
Hello, I’m going to be installing a stand alone computer for the E4OD soon and I’m familiar with some wiring but just need some help locating a 12v under the hood that has power being supplied during cranking and running. They say to use an ignition switched power wire
Old Jun 16, 2024 | 07:05 AM
Olds64's Avatar
Olds64
Check your fuse block for 12V ignition. Use a fuse tap and run the wire through the firewall to the controller.
https://a.co/d/1EjmHQE
Old Jun 17, 2024 | 06:18 PM
gespeter's Avatar
gespeter
On the IDI, the fuel shutoff solenoid is On when key is On. There are a couple more and they all appear at the big Engine Connector at the passenger side inner fender.
Old Sep 24, 2024 | 10:53 AM
cbelll's Avatar
cbelll
6th Gear
I have a 1990 7.3 idi with e4od, it shift normal for about 10 minets then neutrals and I have to rev to 3500 rpm to hard shift, it is my wiring or solenoids?
Old Sep 24, 2024 | 01:27 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What codes are stored in the computer? Here is how to read them: www.troublecodes.net/ford
Old Sep 26, 2024 | 10:37 AM
cbelll's Avatar
cbelll
6th Gear
I will try to read them today, apparently I have to count the check engine flashes or something like that..
Old Sep 26, 2024 | 04:15 PM
cbelll's Avatar
cbelll
6th Gear
I cant find a code reader spot anywhere and in the videos it ha a box with ec test but I cant find that anywhere, where I the scanner located?
Old Sep 26, 2024 | 04:53 PM
cbelll's Avatar
cbelll
6th Gear
i put wires together on for code reader and it does nothing, no flash on OD or check engine light
Old Sep 26, 2024 | 07:34 PM
Mark Kovalsky
Does the transmission shift automatically in drive?
Old Sep 29, 2024 | 01:29 PM
cbelll's Avatar
cbelll
6th Gear
when I first run it in drive it shifts normal in D for about 10 minutes then neutrals/ stays in clutch and will somewhat shift if I hit 3500 rpm but hard, when it does all that recently I've been taking the cap plug thing off that shuts the tach and everything off and I can manualy go 2nd to 3rd but I guess it need electronics to go into 1st manually because it works when plug is in, I would drive it like that but I cant pull trailer without first gear.
Old Sep 29, 2024 | 01:31 PM
cbelll's Avatar
cbelll
6th Gear
so basically yes it works in D
Old Nov 25, 2024 | 06:28 PM
4x4E350Ambo's Avatar
4x4E350Ambo
Just use the constant 12v source from the EEC relay. It’s already intended for your transmission controller/trans so why not reuse it?
Old Nov 25, 2024 | 07:16 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Failed range sensor. (formerly called the MLPS) the large sensor located on the shift lever. Drivers side of trans.
Exactly what I would use also.
(Don't forget to clip that stupid fuel heater line that's cheaply tied into this circuit! Like should be done to all IDI/E4OD trucks. To those who think they need a fuel filter heater, besides probably being wrong haha; run a new fused line for it. To those wise; not only cut it's power, but tap and plug it too! To those most stubborn; Fine, keep a fuel heater, but run your own fused line if you have the E4OD, tap and plug the oem leak point and get a universal wrap style filter instead.)
Kuskoal
Aug 2, 2008 11:51 PM
7.3burnoutbuddy
Apr 5, 2006 09:49 PM
John Deere Ranger
16
Dec 13, 2004 09:43 AM
siphor84
Dec 8, 2003 09:02 PM
