Starter continuously engaging
Old Jun 6, 2024 | 09:05 PM
4.2v698.5f150's Avatar
4.2v698.5f150
1st Gear
Replaced starter and starter solenoid. Re-did the wiring going from the battery to the starter. Did it properly. Everytime we start it now, you can hear the starter continuing to turn basically like turning the key while the truck is already running. Just messing around with it when we realized when we take the wire that goes from the alternator to the solenoid on the fire wall the starter stops engaging and runs normally . BUT. Soon dies bc alternator is no longer charging battery. What’s my next step?
Old Jun 10, 2024 | 11:19 AM
BareBonesXL's Avatar
BareBonesXL
Probably fixed already but it sounds like you misplaced that wire. One of the studs on the solenoid is just a connection point for the wires. Sounds like you connected the alternator charge wire to the solenoid/starter actuating terminal by accident.
Adam Chrisman
Mar 19, 2023 01:41 PM
brokentv
21
Apr 16, 2012 01:29 PM
chubrock108
Oct 22, 2010 07:14 PM
17fordguy
13
Oct 10, 2007 04:16 PM
yolbolsom
Mar 10, 2003 07:27 PM
