starting issues
Old Feb 13, 2023 | 06:15 PM
Adam Chrisman's Avatar
Adam Chrisman
Question starting issues
the starter is not grounding properly. every time i try and start the excursion the starter just clicking. had starter checked twice and both times it tested good. i changed the connection at the starter and still get the same problem.
Old Feb 14, 2023 | 06:05 PM
oharal's Avatar
oharal
Starter is not grounding properly??? What? The starter is grounded by nature of bolting to the transmission or engine I forget which.The batteries are probably dead if its clicking the starter is fine.
Old Feb 14, 2023 | 10:58 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
^^^ The battery/batteries are not holding enough CCA’s and not able to turn the starter
Old Feb 15, 2023 | 05:21 AM
4Kids's Avatar
4Kids
The Struggle Bus¯\_(ツ)_/¯
^^^or the battery terminals are corroded preventing the starter from drawing enough amps to work.
Old Feb 15, 2023 | 07:01 AM
BassFantasizer's Avatar
BassFantasizer
^^^ That would be the first thing to check. There could be enough corrosion on the post to interfere with conductivity and be barely visible with the cable attached.
When reconnect the cable, be sure to apply dielectric grease to reduce further issues with corrosion!!!
Old Feb 19, 2023 | 03:22 AM
Adam Chrisman
band new batteries new starter connections are all cleaned and getting good volts and amps to starter, but still just clicking when you turn the key
Old Feb 19, 2023 | 07:37 AM
oharal's Avatar
oharal
Well if the batteries are good, connections are good and the starter is good, then there's no problem.
Old Feb 19, 2023 | 07:56 AM
4Kids's Avatar
4Kids
I would swap out the starter relay, just to be sure that isn't the issue. I would also bang on the starter (with a rubber mallet, block of wood, etc.) while someone is trying to start it. I've done this several times to get a faulty starter going. Sometimes the starter still 'works' but its going bad. This same trick can be used on a fuel pump or other electric motor. It doesn't fix the problem, just gets you going until you can fix the motor.
Old Feb 19, 2023 | 07:51 PM
Adam Chrisman
ok new problem got another new starter and now the negative cable on the passanger side is getting hot and sparking wtf im at a loss now any help would appreciated
Old Feb 19, 2023 | 07:58 PM
oharal's Avatar
oharal
Is your big starter wire touching something metal?? you're shorting out somewhere!
Old Feb 19, 2023 | 08:19 PM
Adam Chrisman
will check in the am just to pissed right now so im looking for new fog lights and trying to find a 2005 front header panel so i can change head lights
Old Feb 19, 2023 | 08:24 PM
Adam Chrisman
thankx oharal for the quick reply
Old Feb 21, 2023 | 01:59 PM
Adam Chrisman
ok found and open circuit on 1522 that is taking me to the transmission range sensor any help will be helpful
Old Feb 21, 2023 | 02:02 PM
Adam Chrisman
post b on starter was grounding out on drain plug for engine block now ive found a open circuit on 1522 wich is the trans range sensor
Old Mar 19, 2023 | 01:41 PM
Adam Chrisman
Question range sensor
what would cause the range sensor to short out
Full-Time Ford
6.7L Power Stroke Diesel
30
Sep 28, 2017 07:35 AM
Engalwood
21
Feb 21, 2013 11:47 AM
mac01
24
Nov 27, 2009 03:01 AM
sckootter16
Oct 13, 2008 03:32 PM
Randyb12
Feb 7, 2004 02:53 PM
