Hello,
Looking for a little help. My fuel guage is not working properly. When I ground the wire for the gauge it reads full. I pulled the sending unit and it was non functional so I purchased a new Dennis Carpenter sending unit. It reads 13.6 to 95.7 across its range. When I fill the tank it won’t read more than half full. Any thoughts? Possibly the IVR? The temp gauge reads.
Is the float mechanically restricted? You could take the sending unit out of the tank and run the float through its travel and see what happens with the gauge. I think the gauge works with 10-70 IIRC so those readings don't sound too bad. If you want to check the IVR: instead of just grounding that wire, ground it through a test light and the light should blink while the gauge slowly rises to full.
So to update, today I pulled the sending unit and while holding it in my hand the tank will read 7/8 full which would be close enough for me. I put the test light on the guage wire and it gives a pulsing light. There are no obstructions in the tank as far as I can tell and the float seems to not have any binding. When I re-installed the sending unit it still only read 1/4 tank when there is close to 3/4 tank.
Out of curiosity I would run a designated ground wire to gas tank sensor and see if your readings change. Or check the o resistance from ground wire or housing on tank to a good ground and see if it changes
Just a little update. I filled the tank and it reads 3/4 on the guage, as I drove the truck the guage dropped. When it reached empty I took a reading from the sensor and it was 41 ohms (approx1/2). I filled it up and it was approx half full so the sending unit is correct (read 94ohms after filling). I ran a ground straight from the negative terminal of the battery to the sender and no change. Is there any adjustment at the guage? I am going to open the cluster and just check and clean the terminals.
