Fuel Gauge Adjustment?
Old Nov 7, 2022 | 11:13 AM
Landman 454's Avatar
Landman 454
My 1976 Highboy project is coming along but when it's full of fuel my gauge reads 3/4. The tank, sending unit and gauge are all new. As I understand the only way to fix this is by bending the float rod on the sender? When I remove the wire from sending unit and ground it my gauge reads full. Luckily for me the tank is behind the seat so at least I have easy access to the sending unit. I have removed and cleaned all my grounds on the truck so I guess that isn't the issue. Any insight would be much appreciated.
Thanks
Old Nov 7, 2022 | 11:37 AM
FuzzFace2's Avatar
FuzzFace2
Where dose the gauge read with say 5 gallons in the tank?
My 2 tanks the needle comes up to the line for E.
I would rather have it read empty like mine with some still in the tank than rear 1/4 tank and run out of gas but that's me
Dave ----
BTW mine read just over the full line when full.
Old Nov 7, 2022 | 12:46 PM
FuzzyBeanBag's Avatar
FuzzyBeanBag
Dave ----
Hey fuzz - side note question; if I understand what you wrote above correctly - when the fuel gauge is at E, it is indication of 5 gallons left? Kinda like reserve function?
Old Nov 7, 2022 | 06:09 PM
1TonBasecamp's Avatar
1TonBasecamp
They are all set up that way from the factory. At least similar anyway... Not specifically with five gallons, just with some left.
No one particular number of gallons that I was ever aware of, but always some left with the needle on E.
Probably the easiest way to tell is to get it to empty then run it to "empty" where it runs out of gas. Can be a bit awkward though if you don't have some extra handy!
But you can adjust both full and empty on most of these senders. I did that on my '71 and got it to read just over the line when full and just under the line when empty. Worked great for me.
Oh, and that was with the original senders (two tanks) with just 5 years and 60k miles on the clock. Seems a high percentage of them seem to have read that way from what I gather on the forums.
You could drain it and see where the needle goes. Then slowly re-fill until you see when the needle starts to read.
Couple of ways to skin that cat.
Paul
Old Nov 7, 2022 | 06:10 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on if it now indicates E it equals 5 gal (reserve) then I'd leave it set there and know you have 5 gal to make it to a gas station.
Old Nov 8, 2022 | 04:12 AM
FuzzFace2's Avatar
FuzzFace2
Yes
When on E I know I still have 5 gallons left in the tanks.
I had a truck that ran out of gas at 1/4 tank and always on the way to the station so i did not want that on my truck.
I may run 1 tank down to E and the other to 1/8 tank before filling up again.
Dave ----
big job
Jul 2, 2020 05:27 AM
elkarcher1716
Nov 24, 2015 09:38 PM
carbs & chrome
May 16, 2015 09:16 AM
wrdabney
Feb 4, 2015 04:18 PM
james gang 1001
May 8, 2006 02:13 PM
