Electrical Issues
Old Jun 2, 2024 | 09:19 AM
RigCity's Avatar
RigCity
Electrical Issues
Recently replaced my alternator it has 3 prongs however the plug on the truck side only has 2 wires. (Part number was confirmed with the vin) Yesterday the a/c started blowing warm system was replaced a few years ago. Than at night the airbag light was dimly illuminating on and off. Today the truck has no issues and a/c is cold. Not sure where to start trying to figure this out.
thanks
Old Jun 2, 2024 | 01:51 PM
udsuth78's Avatar
udsuth78
What were you doing when the AC went warm? I ask because the PCM has final say in AC function. If it sees something it doesn't like it will disengage the compressor clutch to protect the engine. The two triggers I'm aware of for the PCM to shutdown AC is engine overheating and hard acceleration/high rpm. I've seen it happen in a friends truck without the temp gauge even showing a rise. Don't know if this if applicable to your troubles, but thought it worth throwing out there.
Gunslinger44
15
Nov 7, 2023 07:29 AM
cabloom300
Oct 3, 2013 09:08 PM
jamie7375
Dec 21, 2009 12:53 PM
stansfo
Nov 22, 2008 09:20 PM
vans
Dec 9, 2005 05:28 PM
