Obsession v Irate t4
The only complaint I have is that the oil drain for the turbo could have been a little longer due to the o-ring engagement not being completely seated. The Up-pipes were close to the back of the head on one side so I ended up prying them out a bit with the bolts snug and then I gained about 1/8th of an inch. The instructions could have been better but nothing a DIY can't figure out. Other than those things I am very happy with the kit.
I know Sous installed the CSD kit and he likes it.
Can't speak for the Obsession.
Here is a link to my T4/SXE install video:
Additional threads for reference:
FTE'r RacinJasonWV (includes installation write-up)- https://www.ford-trucks.com/forums/1...l#post19273513
FTE'r SRBF150 - https://www.ford-trucks.com/forums/1...onversion.html
FTE'r Brandon_oma#692 - https://www.ford-trucks.com/forums/1...364-5-sxe.html
FTE'r Markus Luukko - https://www.ford-trucks.com/forums/1...el-t4-kit.html
FTE'r Dan V - https://www.ford-trucks.com/forums/1...tall-tale.html
FTE'r Ridedan2 (E99) - https://www.ford-trucks.com/forums/1...e-journey.html
FTE'r LimatW50 - https://www.ford-trucks.com/forums/1...t-install.html
FTE'r FordTruckNoob - https://www.ford-trucks.com/forums/1...l#post19350743
FTE'r JT250 - https://www.ford-trucks.com/forums/1...l#post19378032
FTE'r ESwift - https://www.ford-trucks.com/forums/1...l#post19461845
FTE'r Slowsure - https://www.ford-trucks.com/forums/1...4-install.html
FTE'r Brokestroke 363 shootout - https://www.ford-trucks.com/forums/1...-shootout.html
FTE'r Sous A Tale of Two Turbos - https://www.ford-trucks.com/forums/1...-problems.html
FTE'r PriusLover - https://www.ford-trucks.com/forums/1...-e-thread.html
FTE'r Rick37 - https://www.ford-trucks.com/forums/1...l#post18859967
FTE'r The Finlander (FinnishStroker) compressor wheel world wide (possibly) catalog: https://www.ford-trucks.com/forums/1...l#post20073448
Many other FTE'rs have installed the T4/SXE, but they don't have an "install" thread to link here (that I could find).
I swapped it out with the cast Y from CSD and haven't had a problem. Also, in hindsight, how the obsession mount and up pipes work looks like a better way to do things, more maintenance-friendly with the separate uppies..
Regardless of the kit, I'd retain the stock Y casting (cut it into a Y) and intercooler pipes. Saves cost and they fit like stock.
