4R70W Tranny - mystery component in pan
Old 05-24-2024, 02:46 PM
VitaAnteActa's Avatar
VitaAnteActa
VitaAnteActa is offline
4wd Low
Question 4R70W Tranny - mystery component in pan
I've a 2001 Ford Explorer, 128k miles, purchases as a donor for a restomod project. The Explorer's transmission metal label attached says AODE. However, the electrical connector is black revealing the transmission is a 4R70W. and using an aftermarket controller and wiring harness we confirmed the 4R70W type. The tranny worked in few test drives.
I pulled the pan to replace a seeping pan gasket and found the attached floating freely in the pan full of fluid.
Surprized to find this, I don't know what it is. Does anyone have any ideas what it could be for?
Mystery part
It's plastic, with a rubber o-ring, about 1.5" long.
Old 05-24-2024, 02:52 PM
runthatjunk's Avatar
runthatjunk
runthatjunk is offline
It goes where the dipstick hole is. Just gets pushed into pan when the tube is installed
Old 05-24-2024, 03:20 PM
VitaAnteActa
4wd Low
Thank you....i found that on a youtube as well. ATF never been changed.
Thank you.
jsutton
09-07-2012 05:28 PM
bigdummyford
21
11-29-2009 08:09 AM
pk8950
03-28-2008 06:19 PM
2kcrewcab
1997-2006 Expedition & Navigator
03-09-2008 11:04 AM
ojosdestranger
1978 - 1996 Big Bronco
11-19-2004 05:10 PM
Quick Reply: 4R70W Tranny - mystery component in pan
