C4 slipping?
Old May 24, 2024 | 10:10 AM
MrPie68's Avatar
MrPie68
2nd Gear
C4 slipping?
I recently picked up a Bullnose with a carbureted 302 and C4 Transmission. I rebuilt the rear axle and know that its running 3.55's, with 28" tires. I'm running at 4,000 RPM at 70 MPH which the math doesn't add up when running the calculators... The transmission sounds and feels like it's shifting fine, any ideas why it's spinning so high? I have no idea what torque converter is installed.
Old May 24, 2024 | 10:23 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What stall is the torque converter?
Here is how to determine that: With the trans in D and your left foot HARD on the brake pedal, use your right foot to plant the go pedal on the floor. What RPM did the engine reach? That is the converter stall speed.
NOTE: DO **NOT** HOLD THE GO PEDAL TO THE FLOOR FOR MORE THAN FIVE (5) SECONDS!!!!! MORE THAN THAT WILL DESTROY THE CONVERTER. Idle or fast idle the trans in park after this for at least 30 seconds to cool the converter.
Old May 24, 2024 | 07:51 PM
MrPie68's Avatar
MrPie68
2nd Gear
Looks like a 2000 rpm stall.
Old May 24, 2024 | 08:15 PM
Mark Kovalsky
That's in the normal range for stall. Are you certain the transmission is shifting twice?
Firs
Nov 22, 2023 05:32 PM
rock7174
Jun 19, 2016 04:05 PM
385seriesHemi
General Automotive Discussion
Jun 27, 2006 08:22 PM
76 F-150 390FE
Mar 3, 2006 10:52 AM
otpracer100
Jul 31, 2005 06:36 AM
