tranny pan
Old Nov 28, 2009 | 12:33 AM
bigdummyford's Avatar
bigdummyford
tranny pan
i want to try to modify a tranny pan for extra capacity anyone have any thoughts
Old Nov 28, 2009 | 01:05 AM
Layson's Avatar
Layson
Your better off just sticking in a 6.0 cooler for extra cooling capacity. If you look at a BTS transmission none of them have a large capacity pan...
I think CSIPSD did make a sort of spacer that just lowered the pan down an inch or two..
Old Nov 28, 2009 | 02:09 AM
SpringerPop's Avatar
SpringerPop
.......And your purpose for the extra capacity is?
Pop
Old Nov 28, 2009 | 07:40 AM
Fire Rooster's Avatar
Fire Rooster
Just buy one from hughes perormance. works great and adds 4 qts. all the hardare included and only 130.00. Finned aluminum cools the fluid faster, holds more, not as big as the Mag hy-tek and therefore doesn't hang below the skid plates. and costs alot less. The pic below was right b4 I put the last bolt in. Been on my truck for 6 years. Love it
Old Nov 28, 2009 | 10:57 AM
DieselCamper01's Avatar
DieselCamper01
No proof that extra capacity help keep things cool but it also no proof that it hurts anything either. If you want to go for it Miles.
Old Nov 28, 2009 | 11:23 AM
SpringerPop
Their catalog claims lower operating temperatures and longer transmission life, presumably from the extra four quarts ATF capacity.
While the case may be made that the fins on the pan MAY contribute to additional cooling, it would be VERY slight, indeed.
What you'll gain is four more quarts of ATF at the same temperature as it would be without that bigger pan.
As Jay said above, there's no reason to believe anything will be cooler.
If you want cooler, get additional heat exchanging, not additional oil.
Certainly no downside except the money spent.
Looks nice.
Pop
Old Nov 28, 2009 | 12:20 PM
DieselCamper01
I do agree with Po that you will certainly get way more bang for your buck with the bigger exchanger than from more fluid.
Miles, are you able to make a GTG on the 13th at Mikes? You are the one that started the thread after all. LOL
Old Nov 28, 2009 | 04:15 PM
Fire Rooster
I have a tru-cool max in series with the stock cooler along with the bigger pan. I am happy with my set up
Old Nov 28, 2009 | 04:25 PM
SpringerPop
Great for peace of mind, too, especially when towing heavy.
I should probably consider additional cooling, as well. It can't hurt.
Pop
Old Nov 28, 2009 | 05:42 PM
bigdummyford
hmmm
well ya guys thanks for all the advice, its starting to get cold up here and i just wanted another little project to do in my garage.
Old Nov 28, 2009 | 09:53 PM
Fire Rooster
I also have the bypass tranny filter from dieselsite.com. I like it too for added safety.
Old Nov 28, 2009 | 10:14 PM
SpringerPop
To avoid abrading through that stainless braiding, you might consider slipping on some plastic split-loom of appropriate diameter.
Pop
Old Nov 28, 2009 | 10:19 PM
Fire Rooster
I have heater hose round it now. Yup I agree with ya
Old Nov 28, 2009 | 10:52 PM
SpringerPop
That works, and well!
Pop
Old Nov 28, 2009 | 10:57 PM
Fire Rooster
I should probably change the filter. Its been on there since jan 07. But the guage still reads in the green. I have been thru a fluid change and didn't change the filter cuz it was still reading good. But I think I will do it just for the times sake now
