460 EFI Pinging/Over Advancing Issues
Old Aug 21, 2024 | 01:39 PM
  #31
jas88's Avatar
jas88
I agree with the 2nd post in the thread describing the octane rod. How is that any different than turning the distributor? Changing the octane rod changes the position of the pickup coil relative to the reluctor - how is this any different than what a vacuum advance does? Moving the pickup coil inside the distributor while the body of the distributor remains static, or, moving the body of the distributor while the pickup coil remains static inside the distributor is the very same thing - it changes the position of the pickup coil relative to the reluctor.
Old Aug 21, 2024 | 01:43 PM
  #32
Soup bean's Avatar
Soup bean
I would Just make sure the plug is in when you set the timing to 10 degrees
That way you can remove it if necessary, and or switch rods
The octane plug looks identical to the spout plug it is just hidden away in the harness somewhere
I read the article on octane bars. It looks like an L bracket with holes in it. I didn't see mention of another plug similar to the spout connector. Where would it be on an '88 5.0? J Moron
Old Aug 21, 2024 | 04:25 PM
  #33
Soup bean's Avatar
Soup bean
If I understand it right, (Which I'm not sure I do) picture it like a three lane highway. The hall effect sensor is in the slow lane, the shutter wheel is in the middle lane and the distributor cap is in the fast lane. (EDIT: Distributor cap is fast lane, sensor is middle lane, shutter wheel is slow lane.)
Moving the hall effect sensor, via the octane rod, changes it's relationship to the shutter wheel, which is fixed to the distributor shaft, and compensates for the slight affect that the seating of the distributor gear has on the position of the rotor button.
Simple really... Ha ha
So the relationship of the distributor shaft to the hall effect sensor changes, without moving the distributor shaft or the shutter wheel.
Old Aug 21, 2024 | 09:52 PM
  #34
AuroraGirl's Avatar
AuroraGirl
Seeing as how this is your first contribution to this thread, and you offer no solution, your criticism here is overly harsh, don't you think?
Too a point, but when it starts pinging, you've gone too far.
i apologize if I seemed crass, but i was only responding to your comment, it appears the OP has not returned but you were asking for input / giving wht you are doing and i neticed that you have been playing with your timing but you are still using fords TFI/CCD (TFI I think). Im not saying youre a moron but im saying its moronic to play with it, because the computer is quite literally basing everything it does for timing on that assumption, and the lack of a knock sensor (even if you had one, fords sucked) means it has no way to know its going to ping if you were instead adding a bunch of timing out of nowhere.
I should have said more to the why but that has been explained since then, so apologies for the snippyness lol
IF you were using Duraspark II or something and you went carb or something like that, it would make sense.
Old Aug 21, 2024 | 10:02 PM
  #35
AuroraGirl's Avatar
AuroraGirl
near the distributor in the wiring or on the fender near icm (if yours wasnt on distributor)
This is not what you have tho, because those distributors had a rod inside them, this is what you read about :
Purpose of octane adjust shorting bar is to provide optimum spark advance for fuel used. If engine detonates (spark knock), remove octane shorting bar. This retards spark advance about 3-4 degrees. If engine continues to detonate, use fuel with a higher octane rating.
Old Aug 22, 2024 | 03:01 PM
  #36
jas88's Avatar
jas88
Can you tell me in what manual and what page you found this information?
Old Aug 22, 2024 | 03:10 PM
  #37
AuroraGirl's Avatar
AuroraGirl
i did not find it in a ford service manual,i found it on mitchell which sources a lot from factory but not all of it is presented the same way
Old Aug 23, 2024 | 04:44 AM
  #38
manicmechanic007's Avatar
manicmechanic007
You do not need to remove the distributor to replace an octane rod
You just remove the 7/32 screw, and the rod will pivot up and off of the stator
Then you just pull the octane rod out through the slot
There were a few recalls over the years where we had to change those octane rods
Ford used to play with those octane rods and PCV valves for altitude compensation and I/M compliance
Old Aug 23, 2024 | 11:11 AM
  #39
Soup bean's Avatar
Soup bean
Do you think the octane rod could affect hot engine restarts?
Does the ECM change timing on start up, for a hot engine, compared to a cold engine?
Old Aug 24, 2024 | 07:29 AM
  #40
manicmechanic007
On initial start I believe the processor is out of the loop, until the engine starts
But, yes, that rod and its length determine stator position and consequently the timing
I believe that on startup, hot or cold, the processor just uses data tables to determine and set timing
Once it's running the computer takes over, hot or cold
I mentioned the drink of water and the octane rod just to get you all thinking
However
If it pings like hell on pump gas? I would start by giving it a drink of water shortly after verifying the base timing of 10 BTDC
Then proceed on to the octane rod modification or shorting bar / plug removal
Old Aug 25, 2024 | 08:15 AM
  #41
AuroraGirl's Avatar
AuroraGirl
If the wire to the starter relay is not properly doing its job, the engine computer will not takeover timing
this isnt likely at play but a good tidbit to know
Old Nov 30, 2024 | 01:32 PM
  #42
jas88's Avatar
jas88
OK all I can say to the naysayers is that I have been driving this truck for ~3 months now with initial timing on 0 TDC and it runs exactly the same as it always has except it doesn't ping anymore. It runs the same water temp, it even gets the same gas mileage. To me this backs up my claim that initial timing only affects a) timing on startup and b) total timing and I say 48 deg total is way too much for this motor. Now, as winter comes on, I may find it harder to start when cold, but so far, that has not been the case. I wanted to drop total timing 10 deg, and I got that and it didn't mess anything else up, and it was free. I am not seeing the downside here, which BTW none of you who told me I was stupid bothered to explain what that would be.
So, my final word on this - if you have a 460 that pings and you have tried all the other stuff, try backing the initial timing off and see what happens. It's really easy to do, doesn't cost anything, and it's easy to put back if you don't like it.
Old Nov 30, 2024 | 06:58 PM
  #43
1Butcher's Avatar
1Butcher
Did you use a timing light? If you did, is it one of those you can change the flash? If it was at 10degrees, and you adjusted it, then your base timing would have really been 20 degrees.
It really does not matter as long as it's fixed. Thanks for the follow up.
Old Dec 2, 2024 | 09:41 AM
  #44
jas88's Avatar
jas88
Of course I did. Mine is electronic and resets the offset to 0 every time you hook it to the battery.
Old Dec 2, 2024 | 09:47 AM
  #45
1Butcher's Avatar
1Butcher
The problem is fixed but the answer to the problem is suspect. You backed off the timing 10 degrees from stock. That is odd and I certainly would question the timing light or if the crank pulley has rotated. Of course, this would take some time and if your truck is 'fixed' why screw with it more?
