Sometimes slow turning starter, what would you think is the cause?
1988 F350 460
Usually the starter will spin very fast as if everything is perfect. Then sometimes (usually after having run for a little while), it's start off by spinning very slow, as if a 1/2 dead battery. Last night it very nearly didn't get it started. This is a quick starting engine. When I got home, I tried to start it again as a test, it failed to start the truck. Charged up the battery and it was fine.
Pulled the 3 battery cables:
1. battery + to solenoid
2. solenoid to starter
3. battery - to frame and alternator bracket
Pulled the alternator (G3 upgrade from 90's) and starter for testing. Both passed the tests.
Bought and installed new battery terminals, cut off dirty ends and wire brushed the wires to make sure all the connections are clean.
I'm going to do a voltage drop test on the cables, they look good but you never know.
Given that this happened once in maybe 5~8 starts. Sometimes it comes back to life after about 5~8 seconds of cranking slow.
Q1. Does this sound like a ground problem to the starter?
Q2. Is there an advantage/disadvantage to having a direct ground to the starter? I do that on my 73 F250.
Q3. I had the ground go from battery to frame to the alternator bracket, that doesn't seem right, is there an engine grounding bolt or does it really matter?
Q4. do extra ground straps hurt anything?
The following users liked this post:
However, it could still be heat soak. I don't have headers but maybe a heat shield would help.
This is an autolite starter on a stock 460, are they known for heat soaking?
One other note is that after charging up the battery, it goes back to fast starts, but charging the battery would also allow the starter to cool.
There's no particular brand that is prone to that (at least not to my knowledge) and all can be prone to heat soaking. Do you live somewhere where it's hot? Possible it might be a loose connection somewhere as well but where exactly I could not say for sure and doubt that's the problem. I would go through and check all your grounds again and make sure they're good and clean to be safe. I'm no expert when it comes to this but that's my 2 cents.
Yes, I like in a hot, central valley city in California, however this was a pretty cool evening when it happened.
It's about $80 to replace all the battery/starter cables, quite a jump in the last few years... but I'm going to clean and reinstall things and see what happens before I do that.
At this point, it's either heat soak or battery cables, bad ground...
Update. Cleaned up the frame ground and replaced the battery terminal with new one. Cleaned up every contact point and the bolts that go into the block. In about 20 tries, it only turned slow once and then it sped up in about 1/2 the time it did before... so it did improve things.
I did some reading about heat soak and it looks like it is an issue. So I'm going to see what I can do about that. Maybe a fan directly blowing on the starter and something to block heat.
on
Mine did that years ago. I replaced the starter with a lifetime warranty from O'Reilly. I went thru 3 of them before I asked for my money back. I then bought a gear-reduction starter from DB Electrical. I also bought a spare since they are mail order only, but it's still in my toolbox because the first one I got is still going great. I buy only their starters now.
tm0231009
23
01-13-2011 02:43 AM
Lenny35
1997-2006 Expedition & Navigator
16
02-03-2009 07:38 PM
