Toolbox Talk
Are you looking for a replacement tool box for the existing truck?
Or are you looking for a new tool box for a new truck?
Recommendations may differ based on scenario.
Good idea. Let's start with you. What are you working with?
I have cabinets built into the bed sides.
You mentioned trailer hitches, as an example. Prior to having built in cabinets in my present truck, I used to have a regular cab 8' bed pickup, which I had for about 20 years. It was a 1979, and back then, Ford didn't supply receiver hitches on trucks. In fact, receiver hitches themselves were a relatively new thing.
To store the ball drops (stingers) with various size ***** (2", 2-5/16", and back then, 1-7/8"), I took advantage of the open tubing sides of the receiver hitch (aftermarket, since no OEM existed) cross tube, which was the same size as the receiver tube, and stored the extra stingers in the cross tube, turned sideways to maintain a high departure angle.
To secure the stored stingers, I mounted a locking flag plate with a padlock hole in it as an additional "washer" to the ball shank before tightening the ball to the specified 300 ft lbs torque, and then used a heavy braided aircraft cable (bicycle lock) between the lock hole on the flag plate and the truck frame.
I can't show photos because digital cameras didn't even exist back then. I probably have some photos on film, but who knows where the negatives are, if they are even any good. But those drops were big (I had a small lift back in those days, like a neutered Big Foot) and awkward to store in a tool box, so I was thrilled at coming up with a way to store and secure them outside of the box, and still have them on hand for any impromptu need.
The point is... thinking outside the box... what on your list can you store and secure outside of a box? That would dictate the size and type of replacement box you choose, or bed you choose, if buying a new truck.
On my '79, I stored two small gas cans (empty), one on each side, under the bed, tucked between the inner bed sheet metal tub, and the outer bed sheet metal skin. Those cans came in handy one day when I was on a fire trail on the side of the mountain, and a ranger had locked the gate. I had to drive to the other side of the mountain to a different gate, but since that was a totally unscheduled course reversal, I didn't have enough gas (despite dual fuel tanks) to make the journey. So I retrieved my two gas cans from under the bed, walked through the locked gate to get some additional gas, returned to my trapped truck, and journeyed again on the fire road back across the mountain to find freedom on the other side.
It is very useful to carry extra things in a truck, and it is interesting to think about why OEM implementations like the RAM BOX and the pass through box in an earlier model F-150 are not demanded by the market. Perhaps it is because the OEM implementations are not as useful, due to size constrictions. Hey, you wanted to talk tool boxes, so we're talking.
Instead of one box for everything, have you considered distributing the stuff listed above into several boxes?
For 8' full size pickup beds, I would consider combining a pair of aft axle wheel well boxes... perhaps one for your bottle jacks, and the other for your rigging webs, both of which benefit from being protected from weather. Content stored in the wheel well boxes alleviates the congestions of a cross box, if you decide to continue with a cross box.
A huge factor in truck tool box decision making is whether or not you tow a 5th wheel trailer. Not only does a 5th wheel trailer conflict with some tool box solutions like a "Bed Slide" or "Cargo Slide", or drawer systems like "Decked" or "Truck Vault" or "Pack Rat", or above rail side boxes like "Delta" or "System 1" or "Weather Guard"... having the need to tow a 5th wheel trailer also effects how high a gull wing or solid lid cross box can periscope above the bed side rails, without the 5th wheel crushing into it.
So folks will need a little bit better idea of all the different ways you might use your truck, before making any recommendations on what type of tool box, or constellation of tool boxes, to work out of.
I am not a fan of the gull-wing boxes as you can’t put long handled objects inside and the portion under the hinge seems to become a black hole for stuff to hide under
