P0455 Code
Old May 17, 2024 | 03:24 AM
Member No. 1's Avatar
Member No. 1
Rather Be Rid'n!
P0455 Code
Ok, 3 separate times now. . See the explanation in the link.
I looked and didn’t see anything obvious so I’ll continue to monitor the issues. Yesterday was the first time a had the smell of gas and I was near the fuel door.
Wonder if it as simple as a bad gas cap.
P0455 Code Explained
P0455 Code
Old Jan 6, 2026 | 04:23 PM
senecagreen's Avatar
senecagreen
Mine was a cracked hose.
Old Jan 6, 2026 | 05:04 PM
Summers22's Avatar
Summers22
I had this issue with a 2001 Ranger a few months back. Hardest diagnosis EVER.....Installed new gas cap, new vapor purge valve, new charcoal canister vent valve, then bought a smoke machine off Amazon after none of that worked. Leak at top of gas tank on the fuel pump retainer ring. Took the bed off, took off the retainer ring and some bonehead didn't use a gasket when they replaced it. Had the truck almost a year battling this. The PO told me his FIL replaced the fuel pump and that was then only part ever replaced on the truck (just turned 102k). Goodluck with your diagnosis and cure.
Old Jan 6, 2026 | 05:07 PM
senecagreen
Yea Im sure the OP figured it out by now I just wanted to put what I found as one more possibility to check. You can see the cracked hose in photo.
2022 F250 7.3
Old Jan 6, 2026 | 05:24 PM
Summers22's Avatar
Summers22
I didn't even see the date, lol
compaddict
Sep 6, 2022 12:59 PM
GM in a Ford
Aug 8, 2022 04:42 PM
Rrgodfrey75
2021+ F150
Jun 16, 2022 06:55 AM
beerguy5812
Jun 2, 2009 12:59 PM
4.0 Beast
Sep 25, 2006 11:13 PM
