CEL on, P0442 code showing up
Old Sep 25, 2006 | 06:23 PM
4.0 Beast's Avatar
4.0 Beast
went to autozone to have the code read... they gave me 4 things that could possibly be wrong. #1 was a faulty gas cap, or its not on tight... CEL had been on for 4 straight days, today i tightened gas cap and after a little more driving, CEL goes out. is it the cause or are 1 of the others possible?
97 5.0 X
Old Sep 25, 2006 | 07:01 PM
scucci's Avatar
scucci
P0442 - Evaporative Emission Control System Leak Detected (small). See this a lot when owners gas up. They don't get the cap on tight, o'ring in cap is bad, dirt around the cap seal area are some common causes. Sometimes overfilling the tank can cause this code.
Scucci
Old Sep 25, 2006 | 07:10 PM
4.0 Beast's Avatar
4.0 Beast
not related but for some reason every time i get a code (CEL), its stored twice. is this normal?
Old Sep 25, 2006 | 09:28 PM
scucci's Avatar
scucci
Perhaps one is a set cel code and the other is freeze frame or pending code. It depends on the code scanner most likely.
Scucci
Old Sep 25, 2006 | 11:03 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
A small evap leak is almost IMPOSSIBLE to find without an evap-approved smoke detector. I would buy a new cap (cheap fix if that's the problem) then have the code cleared. If it comes back you're going to have to take it in somewhere that has a smoke machine.
Good luck. (Small leak = Hole smaller than 0.020" in size per leak detection calculations)
Old Sep 25, 2006 | 11:13 PM
4.0 Beast's Avatar
4.0 Beast
it already went out on its own just by me taking the cap off and putting it back on.... i am gonna buy a new cap anyway because i want a locking one...
rowekmr
Nov 29, 2014 09:23 PM
Nitramjr
1997 - 2003 F150
Jul 6, 2014 09:29 AM
nuke tech
Aug 8, 2013 09:05 PM
77mud
1997 - 2003 F150
Jun 15, 2013 07:37 AM
MikeB 88
1983 - 2012 Ranger & B-Series
Aug 4, 2010 06:13 PM
