Caliper Replacement Question
Old Jun 2, 2024 | 09:58 AM
  #31
arto_wa's Avatar
arto_wa
There is a pretty good older thread about rebuilding brake calipers:
Rebuilding brake calipers
Old Jun 2, 2024 | 10:31 AM
  #32
Kwikkordead's Avatar
Kwikkordead
I'll add to this discussion a very much overlooked fact. Brake fluid is hydroscopic, meaning it will absorb water right out of the H20 in the atmosphere. Nature abhors a vacuum and there's no water in brake fluid and it's water soluble. So because of that, just about every vehicle on the face of the earth needs to have it's brake fluid flushed out and replaced with new fluid every two years. Look it up in the service specs, it's there. I've seen some real damage to braking systems just due to enough time has gone by without any sort of service work done and now it needs every working component replaced.
Old Jun 2, 2024 | 12:23 PM
  #33
SkySkiJason's Avatar
SkySkiJason
Originally Posted by Kwikkordead
I'll add to this discussion a very much overlooked fact. Brake fluid is hydroscopic, .
It is not only hygroscopic, it becomes corrosive to carbon steel once it has moisture in it.
Another thing many people don’t realize is that you should NEVER add fluid to your brake reservoir. The fluid should be at MAX level with fresh brake pads all around and at MIN level with worn out pads. Filling in between will cause the reservoir to overflow while compressing calipers during brake job. NOT filling provides a visual reference to how much brake pad is left.
I’m sure folks have caused themselves more problems by regularly ‘topping off’ their brake fluid reservoir with contaminated fluid from a bottle grandpa left in the cabinet 20yrs ago.
There are no acceptable amounts of brake fluid ‘leaks’. If you HAVE to add fluid, ya oughta figure out WHY!!
Old Jun 2, 2024 | 03:56 PM
  #34
OldMechanic57's Avatar
OldMechanic57
Once the seal on the bottle is broken, the contamination begins right then. A couple of years back, I finally broke down and bought a power bleeder. It makes replacing the brake fluid super easy and quick with no worries about the master cylinder getting low during the process. Gravity bleeding is fine, just keep an eye on the master cylinder fluid level or be prepared to start all over.
ridecolby
49
Jan 14, 2019 04:31 AM
FarmingF250
16
Dec 30, 2016 11:02 AM
matrix660
2004 - 2008 F150
May 25, 2010 08:06 PM
Skarr
2004 - 2008 F150
Apr 11, 2008 07:10 PM
Steve78
Jul 25, 2005 04:53 PM
