Sponsored by: Kumho
Collapsed brake line?
Old Jul 24, 2005 | 11:14 PM
Steve78's Avatar
Steve78
How do you know if your brake line has collapsed or if it is just stuck calipers or pistons?
Old Jul 25, 2005 | 05:45 AM
stuart1's Avatar
stuart1
Loosen the line.
Does the caliper release?
If it does the line is faulty.
If not the caliper is suspect.
Old Jul 25, 2005 | 01:25 PM
jtmerritt's Avatar
jtmerritt
Not sure lossening the line will indicate a bad caliper or not. The suction of the brake fluid through the caliper causes the piston to retract slightly and if the line is bad and collapses it will cause the piston to drag. Caliper piston has no other means of retracting without the help of the suction action of the fluid through the brake line. How old are the brake lines?
John
Old Jul 25, 2005 | 04:49 PM
stuart1's Avatar
stuart1
Well if the caliper releases after the hose is cracked open the caliper is good.
If not the caliper is bad.
Old Jul 25, 2005 | 04:53 PM
Steve78's Avatar
Steve78
Both the lines and calipers are original. I pulled the right caliper off b/c it would not float on the key. I was basically rusted in spot. I rebuilt the left side caliper and it doesn't seem like it is releasing all the way, but what is all the way? How far from the rotor should the pads retract?
Oldschool2888
Jul 22, 2016 12:23 AM
mic91F150
15
May 1, 2016 07:13 PM
dbbldz
Apr 14, 2016 08:02 AM
kiteman
Jul 21, 2011 05:02 PM
wresleu
1997 - 2003 F150
Jun 26, 2006 08:08 PM
