Sponsored by: Real Truck
Spark plug Torque specs
Old May 7, 2024 | 07:56 AM
PJWhelan's Avatar
PJWhelan
Hello, I have the 2002 F-250 5.4L 2V V-8 and need to know the torque specs for the spark plugs. I have seen a huge range upto 27 FT LBS. Low range was 14 FT LBS> So, which is it without stripping the aluminum heads? Have 240,000 miles on original heads..
Old May 7, 2024 | 08:07 AM
jetty's Avatar
jetty
In my experience stripping is not the root issue. The plugs working their way loose due to vibration and thermal cycling is. Once they unscrew they launch. I torque to 18 and as part of the annual PM I re-torque to the same.
Old May 7, 2024 | 08:30 AM
WE3ZS's Avatar
WE3ZS
My ‘05 2valve V-10 has its plugs torqued to 28 ft/lbs.
There is a video of a guy in a junkyard testing the older short thread modular heads and at around 100 ft/lbs the plugs started to snap off but the the crappy threads in the heads held up fine. Personally I would take the short thread older heads up to 26/28 ft/lbs without any fear, many owners here have and have experienced far less blowout issues.
Old May 7, 2024 | 08:31 AM
PJWhelan's Avatar
PJWhelan
Thanks Jetty. I had a plug blow on me 2 years ago. Unbeknownst to me, a shop put in one of those "auto parts stores" fixes. Anyway, bought a Cal-Van kit and that install went smooth. I always (when it comes to plugs) split the difference between a high and a low published Torque number.
PJ
Old May 7, 2024 | 01:42 PM
Diamnd1's Avatar
Diamnd1
I have performed 2 plug changes in my 2V V10 and torqued to 28ft-lbs with no issues.
PJWhelan
Jan 12, 2023 11:48 AM
Spaznaut
Apr 14, 2021 07:59 PM
Resto Guy
Feb 23, 2017 10:47 AM
vaper
1997 - 2003 F150
Aug 27, 2011 02:56 PM
Ubbzy
Modular V10 (6.8l)
Jun 2, 2010 06:51 AM
