1979 LN-600 trans info needed and VIN decode????
I have a 1979 N600 and can’t figure out any info on it. Need the vin decoded. It has the 371 V8 but not sure of the transmission. It’s definitely a 5 speed manual and when it’s running it will go into gear with or with out clutch but won’t move. Anyone got an idea of why??
VIN - N60AVFA5141
VIN - N60AVFA5141
Welcome to FTE.
I moved you to Large Truck as this is the place for that truck. I'll get back to you later today on the decode.
Transmission information is not found in the VIN. You should have a warranty plate on the driver door with VIN, transmission, axle and other information. If you can post a picture of that it can be decoded.
The following users liked this post:
N60 = LN600 gas
A = 370 2V gas V8
V = Kentucky Truck Plant
EA5141 = 1979 numerical series
202 = 202 inch wheelbase
MQ
M = White
Q = Medium Vaquero Metallic
N602 = LN600 gas, 19,500 lbs GVWR (MPC lists this and two others a N600 but N600 ended in '69 per Numberdummy.
8A8 = Standard cab without butterfly hood. I do not have upholstery info
JM
J = Calif. emission. (This is the auxiliary transmission code, also used for certain equipment like emission, fan clutch, French labels....)
M = Clark model 285V five speed direct transmission
61K
61 = Rockwell (Timken) model F106 single speed rear axle, 15,000 lbs capacity, 6.14 ratio
K = Ford front axle, 5,500 lbs capacity, with power steering
19500 = 19,500 lbs GVWR
71 = Los Angeles District Sales Office
No special order.
A = 370 2V gas V8
MQ
M = White
JM
61K
No special order.
If the transmission will go into gear with the engine running, clutch pedal down or up, but won't move, then the problem would most likely be clutch and input shaft related.
Is there a drive shaft in the truck? Did it previously run, shift and drive? Any event associated with the failure?
When you put it in gear with the engine running, does it grind when doing so with the clutch out? Is there any motion or hint of motion?
it wasn’t running when I got it. It sat for years and I had to rewire a few things got it running and it runs great. When I was towing it home the gear would grind if I tried to put it in gear while moving (with or without clutch in) but now that it’s running it doesn’t grind or anything putting it in gear clutch or not. The clutch looks fine… had a suspension it might be stuck to the flywheel but doesn’t make sense that it won’t do anything while engine running.
N60 = LN600 gas
A = 370 2V gas V8
MQ
M = White
JM
61K
No special order.
A = 370 2V gas V8
MQ
M = White
JM
61K
No special order.
thank you so much!!! Very helpful at least now I can hopefully be able to get parts cuz google doesn’t have much at all on this truck. I have a question though… you said the N600 stopped in 69 but the tags on the door says 79 what’s up with that? Here’s the other tag in the door jam
The truck has set for a number of years so it’s most likely it was stuck, it’s most likely in working with the truck to get it going the clutch center has broke or stripped out, the only way to know this is remove the trans and take the clutch out
As a secondary thought with the engine running and transmission in gear check to see if the drive shaft is turning, many of those trucks had 2 speed rear axles, it’s possible that operating the 2 speed switch on the shifter has gotten the rear axle shifted between high and low thus the axle is in a neutral position
