VIN Decode
Old Jun 26, 2008 | 11:29 AM
mjseimas's Avatar
mjseimas
VIN Decode
I need help with a VIN decode please.
1972 Ford F600
VIN F60DCP30429
WB 156
Color M
Model F605
Body 4B8
Trans 4
Axle E20
Many thanks in advance for your help.
Old Jun 26, 2008 | 12:44 PM
Dr. Dirt's Avatar
Dr. Dirt
did you try the VIN Decoder? if not here it is
VIN Number Decoder offer to you by Ford Trucks Enthusiasts | www.ford-trucks.com
oh and welcome to FTE!
Old Jun 26, 2008 | 12:56 PM
mjseimas's Avatar
mjseimas
Thanks, I did try that and several other decoding sites but no luck. I have only found that it was manufactured in Ontario, Canada. Thanks for the link though.
Old Jun 26, 2008 | 07:20 PM
Dr. Dirt's Avatar
Dr. Dirt
huh, that's funny cause every time that I decoded my stuff it turned out just fine.
Old Jun 26, 2008 | 07:28 PM
Mike's 77's Avatar
Mike's 77
I've had the same luck with VIN decoders. I tried obtaining a build sheet from ford even and that turned up nothing...so far. But you could try going that route and going to ford's website and going to "contact us" send them an email requesting a build sheet and give them the VIN. Hopefully this will get you the information you're looking for.
Old Jun 26, 2008 | 07:40 PM
Dr. Dirt's Avatar
Dr. Dirt
well, I tried decoding it for you (I thought maybe it was just y'alls computer or something). I guess I got the same thing as y'all. it said like everything is unknown or something. but it did say May 1972 as built date.
Old Jun 27, 2008 | 06:57 AM
mjseimas's Avatar
mjseimas
Thanks for trying. I have tried everything, even going to Ford but they say they no longer have the records. I was hoping that someone would have an old shop manual with the information on the vin decoding (normally found in the first 10 pages. When I bought it, it said that it was a 1974. I have rechecked the vin several times to make sure there is no mistake. I have spent hour on the internet hoping to come up with something. No luck
Old Jun 27, 2008 | 07:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1972 Ford F600
VIN F60DCP30429
WB 156
Color M
Model F605
Body 4B8
Trans 4
Axle E20
Welcome to FTE
Look no further, the Big Dummy can decode every Ford Truck VIN from 1948 thru 2002.
F60 = F600 2WD
D = 330 Heavy Duty FT Engine / 2V Carb
C = Ontario Canada Truck Assembly Plant
P30429 = 1972
156" Wheelbase
M = Wimbledon White
F605 = 1972 F600 2V Gas / 19,200 lbs. GVWR
4B8: 4B = Heavy Duty Black Vinyl / 8 = 81A Standard Cab
4 = Clark Model 280VO / 5 Speed Overdrive
E20: E2 = Eaton Model 16244 2 Speed Rear Axle / 6.17-1 & 8.58-1 / 17,500 lb. Rear Axle Capacity / 0 = ?? > >
> > Look at that third digit of 0 again, that's the weight code for the front axle, but there's no 0 (zero) listed. Should be a letter, but not an O. Could be a D?
VIN & other data decode source: 1964/72 Ford Truck Parts Catalog
Old Jun 27, 2008 | 07:56 AM
mjseimas's Avatar
mjseimas
Bill,
You are fantastic. Thank you so much for your help. I will double check the number and let you know.
Thank you again.
Old Jun 27, 2008 | 08:12 AM
NumberDummy
The Front Axle Code could also be a number, but only from 1 thru 9.
If the 0 turns out to be a D = Ford-Rockwell (Timken) / 7,000 lb. Front Axle Capacity.
btw: You can buy a CD version of the 1964/72 Ford Truck Parts Catalog (same one I'm using) from hipoparts.com, also sold on ebay. The price is $22.95.
tmcquaw
28
Sep 6, 2014 08:03 PM
nerksa
May 21, 2013 09:39 PM
Rangerdanger33
1983 - 2012 Ranger & B-Series
Jul 18, 2005 06:37 AM
trouble
Aug 17, 2002 11:41 PM
84xlt
Feb 10, 2002 06:07 PM
