1965 N700 Decode
n70MU600830
N70 = N700 gas
M = 330 2V HD FT gas V8
U = Louisville Assembly Plant
600830 = 1965 numerical series, October 1964 production
144 = 144 inch wheelbase
G = Chrome Yellow
N703 = N700 gas, 24,000 lbs GVWR
481A
4 = Beige Vinyl
81A = Conventional Cab. I can't tell if Custom Cab or regular
No auxiliary transmission code showing
A = New Process model 435 four speed transmission
75D
75 = Eaton model 1614-15 single speed rear axle, 17,000 lbs capacity, 7.17 ratio
D = Ford-Rockwell (Timken) front axle, 7,000 lbs capacity
24000 = 24,000 lbs GVWR
160 3800 = 160 Certified Net HP @ 3800 RPM
55 = St Louis District Sales Office
No special order.
Is your pump on the transmission PTO port, or run via a drive shaft from the PTO port on the transmission?
If you have an auxiliary transmission, it was added later. Not uncommon.
Is your main transmission still a 4 speed?
What wheels do you have? Widowmakers were installed on many of these.
trans pump
pass side of main trans
Aux trans tag
A Spicer 5831B has three gear ratios:
2.35:1 under drive
1:1 direct drive
0.85 overdrive
If you have a 4 or 5 speed transmission, I wouldn't be concerned about driving it with those transmissions.
Lots of videos on Youtube of people driving those two stick trucks. My dad drove several over the years. 5/2 and 5/3 transmissions. I remember the first gas engine truck he drove with an 8 speed Road Ranger before the company went diesel with 15 speed deep reduction transmissions.
You had to have the rpms on the money to shift the Road Ranger with a gas engine. Much easier to do with a diesel.
In the 60's and back, these setups were common in gas engine heavy trucks, and many OTR trucks. Macks were famous for their 5&2 duplex transmissions.
