Odd Electrical Issues
Old Apr 18, 2024 | 08:37 PM
  #31
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Absolutely fantastic! Looking good!
Old Apr 22, 2024 | 04:31 AM
  #32
big job's Avatar
big job
Never seen solonoid with button on top should be on the bottom, battery wire driver side stater wire pass side.
Old Apr 22, 2024 | 06:33 AM
  #33
bmoran4's Avatar
bmoran4
The first pictured solenoid is likely this one mounted "upside down": https://cgfordparts.com/starter-sole...01a-11450.html
Old May 1, 2024 | 12:29 PM
  #34
rbjones21's Avatar
rbjones21
Yep oversight on my part. I have to flip it.
Old May 1, 2024 | 12:32 PM
  #35
rbjones21's Avatar
rbjones21
New issue that I have it starting is keeping it running. I am thinking I may have damaged the condenser or points, I can get it started but then it won't maintain and idle. Doing some troubleshooting on it with the points I was able to get to to start and have a strong spark but then it dies after a short time running.
Is the condenser fairly standard on those that I can get from a local parts shop?
Old May 1, 2024 | 12:45 PM
  #36
DieselDog409's Avatar
DieselDog409
sounds like a fuel issue
Old May 1, 2024 | 12:47 PM
  #37
bmoran4's Avatar
bmoran4
Yes, the condenser should be fairly common affair and available from a localish parts place. However, I would caution you from focusing solely electrical/ignition gremlins and seriously consider fuel system side gremlins.
Old May 1, 2024 | 12:49 PM
  #38
rbjones21's Avatar
rbjones21
Brand new fuel, flow is fine
Old May 1, 2024 | 12:54 PM
  #39
bmoran4's Avatar
bmoran4
Carburetor float level? Proper Power Valve and gasket? Proper pressure (about 3psi, much more will overcome the float)?
Old May 1, 2024 | 12:57 PM
  #40
DieselDog409
Clogged carb jet anyone?
Old May 1, 2024 | 01:05 PM
  #41
lshort's Avatar
lshort
I recently had similar with my 66 F100, would barely run, to test it I did not have the correct condenser so I took one I had and just hooked it up to the neg side of the coil and ground, started up and ran great, actually been driving it like that but I need to get the correct one..
I think my problem was chinesium grade ignition parts
Old May 1, 2024 | 06:04 PM
  #42
Brian1950F4's Avatar
Brian1950F4
I find that nonethanol fuel makes a world of difference. Not sure about availability in your area. Not many places have it near me.
Old May 3, 2024 | 09:57 AM
  #43
rbjones21's Avatar
rbjones21
I did replace the points and the condenser which with all the voltage fun was probably good but turns out it was the main line in the distributor, it was shorting out to the case. All good now.
Old May 3, 2024 | 10:02 AM
  #44
bmoran4's Avatar
bmoran4
Great to see a successful resolution on what appears to be a great truck!
Old May 3, 2024 | 01:00 PM
  #45
DieselDog409
I feel your pain dude, dealt with that on my 61 GMC a little while back.
thejoe
Jun 6, 2022 11:47 AM
Captain Sygo
1947 and Older Ford Trucks
78
Oct 3, 2016 09:52 AM
benbuilder
17
Dec 31, 2014 02:26 PM
Rich1953ard
Apr 28, 2013 10:34 AM
jln_Wasabi
Electrical Systems/Wiring
Mar 3, 2004 10:36 PM
