Throwing codes 7E8 and 7E9 A/T
Old Apr 14, 2024 | 04:25 PM
mzcp pumping's Avatar
mzcp pumping
7th Gear
I did a service change fuel filters oil change and right after I did the service I started and it started then died so I got starting fluid and used it and it started drove 10 miles then the engine light came on and it said low fuel pressure ?
Old Apr 14, 2024 | 04:33 PM
Overkill2's Avatar
Overkill2
What year truck?
Old Apr 14, 2024 | 04:44 PM
mzcp pumping
7th Gear
Hi it's a 2014
Old Apr 14, 2024 | 04:56 PM
senix's Avatar
senix
oem filters?
Starting fluid is a last resort, may have messed up the maf or map sensors?
Old Apr 14, 2024 | 05:16 PM
Overkill2's Avatar
Overkill2
One spot to check would be the DFCM, the primary pump, make sure the cap is screwed all the way up to the stops, one on the cap which meets the one on the body.
If the fittings on the secondary filter in engine bay were not tight, there'd be fuel all over but I do believe I read a thread from Ford Doctors about one of the O-rings rolling when that filter was replaced and was sucking air.
Did you do enough priming cycles... turn key to on engine off and allow the pump to run for 30 seconds each time, purging air from the system? I believe the manual says 6 times... I go double that, at least...
Motorcraft fuel filters only, the FD4615 set.
Old Apr 16, 2024 | 06:24 PM
mzcp pumping
7th Gear
Yea I'm gonna get new filters from ford and go from there thanks
Old Apr 16, 2024 | 06:46 PM
Overkill2's Avatar
Overkill2
Read this here before... Use fresh engine oil on the cap threads and the new O-ring... Much easier to screw on...
Old Jan 16, 2025 | 01:28 AM
PopsPlatinum's Avatar
PopsPlatinum
2nd Gear
Engine issues after filter changes
I did the same service and it ran fine until I pressed it a little hard and I got the 7E8 & 7E9 codes. It has happened twice. I get a reduced power message but don't notice anything. The truck is also deleted and tuned. I'm thinking it is one of the position sensors, pedal or throttle.
Normandavis1
1997 - 2003 F150
Dec 13, 2021 04:14 PM
Normandavis1
1997 - 2003 F150
Dec 13, 2021 01:26 PM
Hefurd
Jun 21, 2019 12:29 PM
ernsppw
Nov 1, 2018 01:01 PM
Sheryle
Jan 12, 2008 06:10 PM
